Power on/off with ignition switch?
Old Apr 21, 2013 | 04:49 PM
dn29626's Avatar
dn29626
A while back someone mentioned one of the alternator wires is on/off with the ignition switch. This is perfect for an under hood accessory. Which wire is it on a 2001?
Old Apr 21, 2013 | 07:06 PM
F350-6's Avatar
F350-6
You can also pull it off your GPR or AIH relay. Just use a meter to figure out which one of the little wires is the on and which goes to ground from the PCM.
Old Apr 22, 2013 | 05:02 AM
dn29626's Avatar
dn29626
So the timer for the glow plugs is after the relay?
Old Apr 22, 2013 | 06:51 AM
HKusp's Avatar
HKusp
I believe the timer is from the PCM.
Old Apr 22, 2013 | 06:27 PM
F350-6's Avatar
F350-6
No, the PCM sends a ground signal to activate the relay, but you will find one of the smaller posts on the relay that is hot only when the key is turned on. Use that post and put a ring terminal on the wire you want to get power from and it's a simple way to do it.
Old Apr 23, 2013 | 05:01 AM
dn29626's Avatar
dn29626
Thanks for the clarification.
Old Apr 23, 2013 | 06:03 PM
dn29626's Avatar
dn29626
Each of the small wires read ~.835v with ignition off and ~12v with ignition on or ~13v with engine running.
Old Apr 23, 2013 | 07:22 PM
F350-6's Avatar
F350-6
For the AIH, that's normal since it's rarely ever activated. For the GPR, one post will read ground for the first few seconds after the key is turned on, then return to battery voltage.
I pull of the AIH since it's never used for anything else around here.
Old Apr 24, 2013 | 04:49 AM
dn29626's Avatar
dn29626
So i pull from one of the ~.835's ?
Old Apr 24, 2013 | 07:32 PM
F350-6's Avatar
F350-6
Yes .
timmyboy76
Aug 31, 2018 08:23 PM
jakemb
Jan 13, 2010 09:21 PM
sdwilson68
Aug 18, 2009 09:50 PM
884x4broncoII
May 28, 2008 07:42 AM
WALJON
29
Mar 20, 2008 07:52 AM
