Is this normal??
Old Apr 18, 2013 | 10:54 AM
awillo0406's Avatar
awillo0406
Originally Posted by jeffreyt
What if you go above 55? Does it quit at 65-70?
Yes it is just the 55 mark runs fine above and below but most streets around here are 55
Old Apr 18, 2013 | 10:56 AM
awillo0406's Avatar
awillo0406
Originally Posted by Tugly
EBP - clean sensor and tube. The Exhaust Back Pressure sensor is the feedback to the PCM as to how hard the engine is loaded. If the EBP is plugged up or reading high, the PCM always thinks the truck is under heavy load and will shift accordingly. It also messes with your MPG. It would be best to get a scan tool on it and check the reading against the MAP (they should match +/- 0.2) with KOEO. The sensor is 100 bucks at the dealership, and cheaper from Clay.
Those are the codes I get 0470 & 0478 plan on cleaning/ replacing tube next week.. maybe that is the problem
Old Apr 18, 2013 | 11:43 AM
Tugly's Avatar
Tugly
If Stinky did that, I'd zoom right to the EBP system... that's how much I suspect your EBP sensor.
nickt916
Nov 9, 2012 05:13 PM
kawcrasher
May 30, 2012 09:07 AM
SilverBullet131313
22
Apr 23, 2010 09:46 PM
hedhntr
Aug 19, 2009 01:03 AM
kupaa
17
Dec 5, 2008 10:31 PM
