Official last post for Flatlander Truckfest May 18-19 Central IL
#408
Just to make the stories right,no women whooped me. I had them all under control as they should be. Just think what your grandfathers would think of you men that let your wife's run your life. Just remember if we can get Robbs truck running we can get your wives in line. We just need to work together,and have our own laptops so they can't see these post's.
She hopes you can make it to WI if we hold a meet here. She said something about she knows a few good places on the farm she'd like to introduce you to. Something about no one being able to find you
She also said if you're looking for something to hang from she has a few big Oak trees on the farm. She must be planning a Mexican theme, she said something about using you to help with a piñata, or using you as a piñata?
See what happens when you leave at a reasonable time? And there was no alcohol involved.
#409
#410
For any on you who haven't met Gary he's a little kid magnet, in a good way. You can see he really enjoys having the little ones around him as much as they like being around him.
#412
#413
#414
Bob, thanks for re-posting that video. I can't quit watching it!
Dave, I'm glad you didn't take a swim in the old cistern as you and the others that worked on my truck gave me one of the best gifts I've ever received! Maybe you should find something of Bob's to work on right away at the Dairyland Drive-In next Spring to help keep you safe!
#417
#418
My thoughts for future work on the truck are brakes, finish wiring and doing the interior cab. I've got guages, the floor mat and the orignal seat which needs to be recovered. I also need to decide if my gas tank will work. I'm leaning toward buying a replacement. I've also got the wood to do the rack for the stakebed. Hopefully that will be a Winter project.
#419
Great Rob. Just make sure you install the pump with the flow arrow pointing toward the carb, make sure it's got a good ground and wire it so when the key is on it gets juice to the pump, maybe at the solenoid. Don't wire it to the starter solenoid terminal that only has juice when the key is turned to start.
Then check for fuel leaks with the system on and under pressure.
Now you can enjoy more of those barnyard drives
BJ
BJ
#420
Will this thread ever die?!!!
Just wanted to try to get some information to one of the attendees. I don't remember his name but he had the flat black '51-52 with the door lettering. When I was checking his truck out he had to hold his hood open with a stick because his hinge springs were bad. He said he didn't know where to find new ones. I don't know if the normal vendors sell them but there's some list on eBay, the seller says he has 12 new springs availlable for $5 apiece. He's got a Ford part number in his picture so they must be reproduced.
http://www.ebay.com/itm/Ford-Hood-Arm-Spring-Steel-Car-1939-48-and-Pickup-Truck-1939-47-Made-in-USA-/290895174448?pt=Vintage_Car_Truck_Parts_Accessories&hash=item43bab41b30&vxp=mtr
