Lower my egts
Old Apr 18, 2013 | 07:36 AM
dmanshane's Avatar
dmanshane
900 crusing on flat roaf 70 mph. 1300 pulling 29 foot camper 65 mph on flat and can easilly hit 1500 pulling a small hill but I let out of it
Old Apr 18, 2013 | 07:53 AM
snakedoc's Avatar
snakedoc
for me i would not see 1250 pulling 12000 lbs of dirt up hill at 65mph. and 450 on the flats.
Old Apr 18, 2013 | 09:03 AM
Tugly's Avatar
Tugly
Watch out! Max recommended is 1250... and that's pushing it to the limit. Gear down, slow down, fix the leak, or all of the above. I hope that reading is right on the oultet to the manifold. A reading that high closer to the turbo is way over the top.
Old Apr 18, 2013 | 07:04 PM
Pocket's Avatar
Pocket
Yep, that's hot. Get that exhaust leak fixed ASAP.
Old Apr 18, 2013 | 07:13 PM
dmanshane's Avatar
dmanshane
Yea not good I know. Olus lake season is coming up and that means the camper will be behind her
Old Apr 18, 2013 | 07:22 PM
Macmathews's Avatar
Macmathews
450 on the flats doing 65 mph
That seems lower than normal
Stock injectors , turbo ?
Kyle
Old Apr 18, 2013 | 07:36 PM
Tugly's Avatar
Tugly
Kyle
I'm also curious about the location of the sensor.
Old Apr 18, 2013 | 07:41 PM
Macmathews's Avatar
Macmathews
Tug, just pm.d you
Kyle
Old Apr 18, 2013 | 07:44 PM
Macmathews's Avatar
Macmathews
Just an FYI , my truck runs at least 600 in that situation.
My tires are a little oversized though.
305x65x18
Mbrp exhaust, do tuner, air, rest is stock
Btw - it runs slightly cooler in 80e than it does in the stock tune
Old Apr 18, 2013 | 11:50 PM
snakedoc's Avatar
snakedoc
it should have been 650.
both are right on the manifolds. i cant get to 1200 if i try. stock turbo and sticks. BTS tunes
Old Apr 19, 2013 | 03:59 AM
Tugly's Avatar
Tugly
I see 575-650 at highway speed on the flat with no wind and I set my alarm at 1200. I haven't seen it light up on my 160/100s with my current tunes. Maybe when I tow this summer... but the tow tune might prevent an alarm.
Old Apr 19, 2013 | 06:46 AM
dmanshane's Avatar
dmanshane
I have a glow shif gauge and the probe is on the outlet of the lh manifold
Old Apr 19, 2013 | 07:32 AM
  #28
dmanshane's Avatar
dmanshane
Old Apr 19, 2013 | 07:33 AM
  #29
dmanshane's Avatar
dmanshane
Old Apr 19, 2013 | 09:06 AM
  #30
timmyboy76's Avatar
timmyboy76
damn!!! #26 with a cracked butt
