215/223 alternator conversion
Old Apr 13, 2013 | 01:15 PM
51PanelMan's Avatar
51PanelMan
I've searched Google and wasn't successful. I'm trying to find a picture or someone who has converted their 215/223 from a generator to an alternator. I'd like to see the bracket and how the alternator attaches.
If you have done this conversion yourself, I'd greatly appreciate a brief pictoral and/or written "how-to".
As per Ross's suggestion, I may switch out to a 6v pos alternator and ditch the stock generator.
Old Apr 13, 2013 | 01:51 PM
HkyswiM's Avatar
HkyswiM
Subscribing
Old Apr 13, 2013 | 02:02 PM
teardropty's Avatar
teardropty
Here's my setup on my 223. I will try to find my writeup and post in a few.
Old Apr 13, 2013 | 02:08 PM
teardropty's Avatar
teardropty
I used a Delco 3-wire. Here are a couple of links that explain the setup, etc. I used the factory generator bracket and a couple of washers, threaded rod and some nylock nuts. I slid the threaded rod through the factory bracket that bolts to the block. The threaded rod acts as the pivot point for the bottom of the alternator and then the original generator bracket arm bolts to the top of the alternator for your adjustment.
The Delco 10-SI and 12-SI Alternators
Catalog
OneWireAlternator
As for the 6 volt alternator. If you are staying 6 volt than you have to go that route but if you are upgrading/updating to 12 volt, I highly recommend the 3 wire setup, even over a one-wire setup. The 3 wire is out of an early 84 Cheby Camaro, 305, 4 bbl. The reason I like it is the cost factor, the easy availability and easy of use. GM one-wires cost more, sometimes harder to get a the local NAPA store on a Saturday afternoon and it's about the same hooking it up as a 3 wire.
Old Apr 13, 2013 | 03:42 PM
51PanelMan's Avatar
51PanelMan
Thanks for the info. Do you have a picture of the bottom mount?
Old Apr 13, 2013 | 04:09 PM
raytasch's Avatar
raytasch
Believe Nothing
JMHO, but if I were converting to an alternator, I would convert to 12 volts negative ground. You are already non stock so why not have the advantages of 12 V? As mentioned, the three wire GM alternators are readily available and cheap. Sell that expensive Optima six volt battery and move on. Again, JMO.
Old Apr 13, 2013 | 05:04 PM
teardropty's Avatar
teardropty
I can take some detailed photos on Monday and post. The truck is 2 hours away from me right now. Will post on Monday.
Old Apr 15, 2013 | 11:41 AM
51PanelMan's Avatar
51PanelMan
Thank you for the info and the pictures. If you can still get a picture of the bottom mount, that would be great. No sweat if you can't.
I've decided to go ahead with the alternator conversion, but not a 12v conversion yet. I'll hold onto the generator to have rebuilt later for "just in case".
Old Apr 15, 2013 | 12:29 PM
Indybeer's Avatar
Indybeer
I made my own bracket and attached it in same location the generator was installed
For the upper adjustment arm I found this bracket in the local pic a part yard in a mid 60's Ford pickup
Old Apr 15, 2013 | 06:22 PM
teardropty's Avatar
teardropty
Didn't forget about you, just got busy today. Look for it tonight or tomorrow. Thanks.
Old Apr 15, 2013 | 07:06 PM
turnrjr's Avatar
turnrjr
One of my galleries shows how I did mine. Check it out. On another topic, your new lettering on the panel is neat. Like it a lot.
Bowsandovals
Jul 12, 2016 07:48 PM
schoo
May 26, 2013 08:56 AM
Tumblindyce
Aug 17, 2009 11:24 AM
Paso1
Jan 30, 2009 03:43 PM
Ole' Green
Sep 28, 2007 07:25 AM
