Alternator it is...
Old Jul 11, 2016 | 01:24 PM
Bowsandovals's Avatar
Bowsandovals
Alternator it is...
I decided to swap the generator for an alternator on my 49 F6 coe. The generator took a dump so rather than mess with that anymore, I bought the conversion bracket from Speedway,$39 and the 5/8 pully from speedway,$15. I then purchased a new mid 70's GM alternator from Oreilys for $45. I opted for a 2 wire alternator.
Old Jul 11, 2016 | 01:30 PM
Bowsandovals
I decided to trim the bigger alternator tab off to match the other side. It made it easier to stack up spacers to achieve the proper pulley alignment.
Old Jul 11, 2016 | 01:34 PM
Bowsandovals
The fan/generator bracket setup that Ford designed defies logic, but we were able to get it installed. You have to buy new coarse thread bolts for the speedway bracket. The factory ford bolts are fine thread.
Old Jul 11, 2016 | 01:36 PM
Mixer man's Avatar
Mixer man
I had no problems at all with fitment. You must have a V8. Ok, never mind.
Bowsandovals
Front view.
Old Jul 11, 2016 | 01:43 PM
drptop70ss's Avatar
drptop70ss
Very cool, I use those alternators on everything. 1973 to at least 1985 GM, I just order one for a 1975 Camaro.
Here is the wiring diagram in case anyone needs it.
Old Jul 11, 2016 | 01:45 PM
Bowsandovals
I wired it according to this diagram but used a diode in place of the lamp. I have the factory volt gauge to tell me if it is working. The diode prevents back feed of voltage.
Old Jul 12, 2016 | 06:24 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Looks to be the same wiring just one is more old school.
Old Jul 12, 2016 | 12:11 PM
Mixer man's Avatar
Mixer man
Curious, what backfeed do you expect with the key switch off?
Old Jul 12, 2016 | 01:29 PM
raytasch's Avatar
raytasch
Believe Nothing
Some of these GM alternator installations will feedback into the ignition and prevent engine shutdown. That is why the diode or some kind of load is placed in the P1 circuit. It is rumored that GM and others put a resistive wire in the circuit to prevent feed back. The install in my 1949 F4 with EZ wiring kit worked fine for two years and several thousand miles and then the engine suddenly would not turn off with the key. Obviously getting feedback into the HEI system. I pulled the P1 wire from the alternator, taped it back into the harness, and all is working fine. I run a voltmeter so I can tell the alternator is doing the job. I suspect the P1 is used for exciting the alternator only and mine must retain enough residual magnetism. I am pretty familiar with electrical systems but just never figured it important to figure out the "why". I've installed several GM alternators on old Ford tractors and always installed a small marker light for a load. HPFM?
Old Jul 12, 2016 | 04:21 PM
Mixer man's Avatar
Mixer man
Precisely why I installed a battery cut out solenoid.
Old Jul 12, 2016 | 07:48 PM
drptop70ss's Avatar
drptop70ss
P1 wire needs some resistance to excite the alternator, I use a 120 ohm resistor or a idiot light depending on application, never heard of feedback into the ignition system myself. Maybe the internal regulator shorted feeding power back into the ignition switch?
Only resistor wire I know of in GM applications is in the ignition circuit of 1974 and older cars that used points, drops the 12v to 9v, but HEI uses a full 12v.
svolpone
Dec 9, 2014 03:55 PM
schoo
May 26, 2013 08:56 AM
Mr.Puff
Apr 29, 2012 11:13 PM
JoeTaco1
Jun 21, 2010 09:06 PM
1960 F100
Aug 28, 2007 09:54 PM
