Por 15 question
Old Apr 13, 2013 | 11:06 AM
brwolfjr's Avatar
brwolfjr
Por 15 question
I have a new oil pan and i have the por 15 starter kit. Should i just paint the pain with por 15 or should i sand it first? The instructions keep talking about the best bond to a rusty surface, but i am having a tough time bringing myself to take a wheel to this. I also have a few rattle cans of por 15 rubberized under coating. Input is appreciated.
Old Apr 13, 2013 | 11:27 AM
Tugly's Avatar
Tugly
Covering the rust with paint just means the rust will grow and push the paint/coating off. You can try hand-sanding and that rust catalyst as a primer... it's a small area. I need to read up on Por 15 before I fully understand what you're doing.
Old Apr 13, 2013 | 11:33 AM
brwolfjr's Avatar
brwolfjr
Hi Tugly
This is a new pan. No rust yet.
I am trying to avoid rust down the road.
Old Apr 13, 2013 | 11:41 AM
Tugly's Avatar
Tugly
I was confused for a sec. I saw "new" and "bonding to a rusty surface" in the same post and my coffee couldn't compensate. Clean the bejeezuz out of it with something like brake cleaner after it's scuffed a little. Whatever solvent you use, make sure there is absolutely zero residue on the pan... not even fingerprints (or powder from gloves).
Old Apr 13, 2013 | 03:25 PM
AMG-SM's Avatar
AMG-SM
Give it a light sanding to make the primer and paint easier to adhere. The paint sticks better if you follow their whole prep - from the degreaser onward.
Old Apr 14, 2013 | 09:52 AM
F-250 Super Duty's Avatar
F-250 Super Duty
I used POR15 on my old pan once it was rusted. With us living in the rust belt I honestly think it may have bought me another year but ultimately the rust won. POR15 is a great product that has a very strict application process that needs to be follow to a "T". I would definitely sand it first and make sure it had something to grab ahold of.
I went the other route and just had mine Rhino Lined. They charged me $50, by the time I would have bought all the POR15 prep and application stuff, I would have been well past $50.
This entire pan was POR15'd at one time. Granted I do spend quite a bit of time at the shore but we are not that far from each other in the big picture. Make sure you stay on top of it to repair chips in the paint from stones and such, avoiding letting the rust start from the get go.
Old Apr 14, 2013 | 10:14 AM
Snowseeker's Avatar
Snowseeker
NO. If it is new do not POR it because it will peal off.
Personally I undercoat new pans.
I would personally use any sort of heavy paint method before even considering PORing new metal/paint.
Old Apr 14, 2013 | 10:20 AM
Snowseeker's Avatar
Snowseeker
It is important when PORing rusted surfaces to first knock off and scrape any loose rust. POR works best on surface rust, it does not work on flaky bubbled up rust.
This was the case with my lower drivers door. In this picture you can see all the flake and bubbly rust has been knocked off and all that remains is just a nice surface rust. This is the absolute best base for POR15! I have had many many years of battling rust and like to think of myself as a rust pro!
Before any work done:
Old Apr 14, 2013 | 01:44 PM
Ford79's Avatar
Ford79
I have never used POR15, but a couple years back when I replaced the pan on my truck I used the DIY truckbed liner, in a rattle can. Now, almost 2 years later it looks like the day it was installed. Not saying it is the best thing out there but it worked good for me.
Old Apr 14, 2013 | 01:54 PM
brwolfjr's Avatar
brwolfjr
Sanded, marine clean and prepped. First coat is on and drying.
I plan on getting two more coats plus i am going to spray the por15 rubberized undercoating. While sanding, i couldn't believe how thin the paint was in some spots. I also thought some of the spot welds looked like prime areas for rust if i had not treated the pan.
Old Apr 14, 2013 | 02:10 PM
brwolfjr's Avatar
brwolfjr
How does the dip stick tube stay in place? Am i missing something?
Old Apr 14, 2013 | 03:23 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Mine has been on a year, still looks great.
Old Apr 14, 2013 | 04:54 PM
megawatt00's Avatar
megawatt00
Great idea.. I am going to have to do this as well
Old Apr 14, 2013 | 05:48 PM
Snowseeker's Avatar
Snowseeker
After all was done I took a syringe and injected por into the clip holes as well. I did the same on the the other doors even if they were showing rust just to be sure.
Supercab
Jul 25, 2016 03:27 PM
godblessmud
Paint & Bodywork
Sep 27, 2007 02:47 PM
tolmite
Jun 22, 2007 11:39 AM
MickeyP
Paint & Bodywork
May 12, 2003 08:42 PM
