E4OD Shifting Hard, please help!!!
Old Apr 16, 2024 | 01:09 PM
  #76
Doyle’s Shade Tree's Avatar
Doyle’s Shade Tree
2nd Gear
Originally Posted by hjartland
At least for my part. My 93 F-150 is shifting much better after cleaning the VSS in the rear axle & putting new capacitors in the computer.
I may need to check on that next. I’ve done so much work on this 94 E350 lately. Every now and then the hard shifting would be butter smooth for just a short bit. But it would go back to the hard shifts 10 minutes later. It’s leading me to either the VSS or the TPS but checking the computer may be a good idea.
Old Apr 16, 2024 | 01:26 PM
  #77
hjartland's Avatar
hjartland
I checked my TPS w/ an ohm meter and it checked out OK.
The VSS had some small metal chips on it. Suppose that happens over 200,000 miles. I cleaned out the rear axle with brake cleaner. Checked for any signs of gears not messing, but it was all good.
Reinstalled the cover, and put in new fluid. Between that and the new caps in the computer. My 93 is shifting much better.
srsparky32
31
Nov 1, 2016 09:51 PM
Kallie
Oct 20, 2007 06:52 PM
ptt
Apr 10, 2006 04:18 PM
