E40D shifting ungodly hard
Old Oct 31, 2011 | 06:19 PM
srsparky32's Avatar
srsparky32
this just started happening. my baby is shifting super hard
it does it from a dead stop, 1st to 2nd. very hard shift. gets better the higher up in gears. if i start off in second gear, and then shift back to drive after 1st gear shift (20-25 MPH) its a lot better and i dont experience the hard shift.
also, shifting into reverse or into drive has a clunking noise and a very hard jerk to go along with it.
so..can the experts here tell me whats wrong?
Old Oct 31, 2011 | 06:35 PM
ravens fan's Avatar
ravens fan
im no expert but how many miles are on it? it could just be getting wore out mine had some hard shifts esp 1st to 2nd i put some lucas tranny fix in it( it supposed to help tranny slip and hard shifts) it has helped greatly in my case!
Old Oct 31, 2011 | 06:36 PM
86F150302's Avatar
86F150302
Common E4OD problem.
First check codes.
Could be MLPS, RABS,or TPS.
If you search you can find alot of info.
Old Oct 31, 2011 | 06:41 PM
srsparky32's Avatar
srsparky32
it has 113,000 miles on it.
First check codes.
thats what ive been hearing. ill check the codes. but do you think its electronical or mechanical
Old Oct 31, 2011 | 06:46 PM
ravens fan's Avatar
ravens fan
yeah nevermind then it shouldnt be wore out with that many miles lol mine however has seen better days
Old Oct 31, 2011 | 06:49 PM
srsparky32's Avatar
srsparky32
yeah im just driving my dad's 2004 GMC sierra while we figure this problem out and it sucks. i want my baby back : )
Old Oct 31, 2011 | 06:56 PM
86F150302's Avatar
86F150302
Id put my money on a sensor before an actual mechanical issue with the E4OD any day. I had the same problem at 79k miles and it was the mlps.
Old Oct 31, 2011 | 07:01 PM
srsparky32's Avatar
srsparky32
how much did that cost you to replace? did you have a shop do it? you diagnosed it with a code reader right?
Old Oct 31, 2011 | 10:33 PM
86F150302's Avatar
86F150302
E40D manual lever position switch MLP E40D Range sensor PRND21 switch
No only thing I don't do myself is alignments and tires.
I did not use a code reader for the MLPS. I was just told on another website that was what was causing my issues. But you should always pull codes first before buying parts that you arnt 100% sure are bad.
Old Nov 1, 2011 | 02:49 AM
ryito1122334455's Avatar
ryito1122334455
mine was doing the same thing, i installed a new vss (vehicle speed sensor) on the rear differential....took about 15 minutes. also disconected my abs (rabs)........reset the computer my unhooking batt cables for a minute......never had the problem after that......could be many different problems tho....this was just my senario hope it helps
Old Nov 1, 2011 | 11:40 AM
srsparky32's Avatar
srsparky32
well it was shifting fine this morning and wasnt as hard so my thinking is a sensor.
Old Nov 1, 2011 | 11:43 AM
ryito1122334455
yup mine did the same thing, sometimes it would shift ok, and sometimes hard as a rock.....i bet if you swap out the vss (like 12 bucks at autozone) itll fix it, atleast its worth a shot....u dont even gotta lift up the truck and it only takes a couple minutes...and its only 1 bolt... just use pb blaster and a leverage bar on your wrench, itll pop right out. just remember to reset your computer by disconectin your battery for a bit
Old Nov 1, 2011 | 11:51 AM
Kemicalburns's Avatar
Kemicalburns
start with the sensor on the rear diff. remove it and wipe it clean and reinstall it and drive to see if it improves.
is your speedo working?
Old Nov 1, 2011 | 12:17 PM
Superduty.pride's Avatar
Superduty.pride
Saved
My 1990 Did exactly the same thing when I bought it, feels like you're getting rear ended when it shifts, especially when shifting 1st-2nd?
I checked my engine codes, my Throttle Position Sensor came up as malfunctioning, the TPS tells the E4OD when to shift, without that information it uses preset shift points, which are usually both wrong and very hard, the new TPS cost me about $25 and took only about 30 Minutes to replace, and it was completely better after that, as well as added benefits on my truck.
So I suggest looking into it. Good Luck Bud.
and get on it cuz that hard shifting can over time damage your transmission.
Old Nov 1, 2011 | 01:23 PM
srsparky32's Avatar
srsparky32
speedo is working, yes.
Indeed it does sir. and a bad TPS is my conclusion as well. its likely as well, since 113K has passed without any electronics being serviced.
