Vacuum leak
Old Apr 11, 2013 | 09:09 PM
Mike in Ohio's Avatar
Mike in Ohio
Vacuum leak
Would a vacuum leak cause a massive drop in mpg? By massive I mean from 9 to 6.
I have a 460 in my '69 f250 so it is not original and I don't think it is stock either, but don't know for sure. It has a points ignition though so I think it is pre '75. Was running rough I went around the manifold with starting fluid and sure enough when I hit on the front drivers corner it smoothed right out. Pretty much right behind the distributer.
As a short term fix could I run a bead of rtv or something else along the seam to seal it up? Or would this just be a waste of time and materials?
Thanks, Mike
dharte
Nov 1, 2014 06:28 PM
blaze 57
Aug 25, 2013 09:03 AM
larry3
Aug 7, 2011 06:58 PM
dagray3
24
Nov 30, 2007 11:43 AM
