A/C vacuum leak
Old Aug 11, 2013 | 01:57 PM
blaze 57's Avatar
blaze 57
A/C vacuum leak
Trying to track down an air conditioning problem. Seems like a vacuum leak somewhere is screwing with my AC and shutting it down upon giving it any throttle (hills etc). Where should I look first or is there a certain area that is prone to leaks?...truck is a stock 1993 F-350 460/auto. Thanks!
Old Aug 25, 2013 | 09:03 AM
JWA's Avatar
JWA
Somewhere between your intake manifold's port for A/C vacuum and your dash vent servo motors you have a vacuum leak. Most likely its at the vacuum reservoir---I'd start checking all lines to see if there's anything readily apparent.
dharte
Nov 1, 2014 06:28 PM
HerbW
1997 - 2003 F150
Jun 4, 2014 08:27 PM
inspector1
Feb 19, 2008 07:26 PM
