'72 460 distributer
Old Apr 3, 2013 | 01:28 PM
Michael Hoskins's Avatar
Michael Hoskins
'72 460 distributer
What is the best way to break my distributer loose on my 460. It's timed to 4 degrees and I need to advance it to around twelve. Any ideas that don't involve breaking it?
Old Apr 3, 2013 | 02:10 PM
montana_highboy's Avatar
montana_highboy
Bring the engine up to operating temp, remove hold down clamp and saturate base with PB Blaster, let soak in then "tap" around the base with a blunt object and hammer, repeat as often as needed, it will eventually free up.
Old Apr 13, 2013 | 11:28 AM
BigBlockF350's Avatar
BigBlockF350
The distributor on my '73 460 was stuck at one point too. I sprayed it with penetrating oil, and got it loose with a big pair of vice grips the next day. I put some rubber hose on the vice grips to keep them from marking up the distributor. After that, I was able to turn it easily by hand.
olyellow
Jun 23, 2013 09:51 PM
Magic
Mar 25, 2007 02:33 AM
dlister
Dec 4, 2006 12:44 PM
Ratsmoker
Oct 23, 2001 10:17 PM
primetime
Jun 5, 2000 05:06 PM
