Cruise control not working
Old Apr 11, 2013 | 02:37 PM
SpringerPop's Avatar
SpringerPop
There are two sections in that switch.
One is for the starting circuit, the other is for the cruise control.
The wires for cruise are Tan/LtBlu and Red/Yel
FOUR wires coming off that switch, and it's conceivable that one section is bad or mis-adjusted.
I'd look at mis-adjusted first. They can "slip".
Pop
Old Apr 11, 2013 | 02:39 PM
Journeymaaann's Avatar
Journeymaaann
I have a six speed & when my VSS on the rear end needed replacing, my cruise control didn't work. It was ok when I installed the new vss I got from one of our sponsors www.Rock Auto.com 1999 FORD F-250 SUPER DUTY Vehicle Speed Sensor
Old Apr 11, 2013 | 02:51 PM
SpringerPop
A bad VSS will also give other indications, however, and the O/P doesn't tell us of any of those.
In this case, the other symptom would be an erratic speedometer.
If it were an automatic, there would be two more symptoms, but it isn't, so I won't confuse the issue with them.
We still don't know the results of his "third brake light" test, BTW. Stayin' with the simple stuff........
Pop
Old Apr 11, 2013 | 03:26 PM
skyhigh's Avatar
skyhigh
Originally Posted by kawcrasher
Check the pressure switch on the cylinder. If it's leaking it's probably bad. It is just a NC pressure switch, so it easy to check.
I am not sure how the clutch switch is set up. Just check to see if it changes states when the pedal is pushed.
pressure switch on cylinder? What cylinder?
Old Apr 11, 2013 | 03:30 PM
skyhigh's Avatar
skyhigh
Pop
My truck is at the tranny shop getting a new south bend clutch installed so checking what everyone has suggested will not happen till next week. I DO appreciate all the help I'm getting. This forum is the BEST.
Old Apr 11, 2013 | 03:40 PM
SpringerPop
Your brake system's "master cylinder". It's attached to the hydroboost unit. It's under the hood.
We'll talk you through this after you get the truck back and can run some tests to resolve this.
Pop
Old Apr 11, 2013 | 08:58 PM
kawcrasher's Avatar
kawcrasher
Pop
Yep. I was posting on my way out the door. I forgot a few words.
Old Apr 17, 2013 | 07:38 AM
Baatzy's Avatar
Baatzy
I went out to look at my pickup and found that my third brake light isn't coming on. It's still snowing so I haven't had an opportunity to delve into it. Do I just need to replace the bulb or is there a fuse that may need replacing? Thanks for the help!
Ethan
Old Apr 17, 2013 | 08:13 AM
ronjon95's Avatar
ronjon95
I would say its just the bulb. There is just 2 Philips head screws that hold the lens assembly on just remove them and give a quarter turn twist to remove the bulb harness if its black foggy looking its burnt out.
bossgobbler
May 10, 2012 10:30 PM
mah77
Jun 30, 2011 06:04 PM
travis182008
Feb 28, 2011 06:25 PM
IMPRTKLLRZ28
Dec 7, 2010 10:55 PM
