My cruise stopped working while on a trip back from Yosemite with my travel trailer. I picked up and installed a new pressure switch on the brake master cylinder. Took it for a drive, and it worked, so I thought everything was good to go. I hit the brakes to disengage cruise, accelerated, and when I tried to set it again, nothing. Im wondering if the switches may be bad. The tech and parts guy at the dealership said its rare for the clock spring to go out. Puzzled.
That would suggest that the switches or the clock spring is bad. Do your cruise control switches light up at night? And does your horn work? All of those go through the clock spring.
I was told if my horn worked than my clock spring was good. But that was not the case. My clock spring was bad and the horn worked. I too replace the pressure switch and that did nothing. I have heard it is more common for the clock spring to go bad so I went with that and problem solved.
I guess I'll try the click spring next. Everything else works, horn, radio controls, etc. No ABS or airbag light on. Cruise light doesn't illuminate, and when I tried the diagnosis link listed above, nothing happened.
I did not have the cruise control test procedure to go by but I played around with the cruise buttons and nothing worked the air bag light came on about three months later. And most of what I had read pointed to the clock spring except the horn worked so I went for it and it solved both problems. Hopefully it will work for you.
Dealer has the clock spring for $99, and the replacement cruise switches for, **** me!, $92. Both are non-refundable. Really having a hard time deciding which route to go. Everything else works, and I have no codes or airbag light. If we were talking $20, no biggie, but $100 per........Grrrrrr.
