'89 f250 7.3L IDI home made turbo kit
My truck has true duals on it though, which might be a problem when trying to install a turbo. What I was wondering, if I can track down a turbo, how difficult is it going to be to actually install it and make all the bends for the exhaust. I dont have a welder or pipe bender which would make this extremely difficult.
There has been someone on CL near where i live listing this turbo for months and he is trying to get rid of it.
http://morgantown.craigslist.org/pts/3688425157.html
He says its a garrett T-3/T-4 I dont know if this would even fit.If it does, it might be worth just having my local exhaust shop set it up. Any help?
A Garrett T-3 is the same turbo that's used in the 7.3 factory kit and the ATS 093. So I'd think the turbo should be good, though the A/R ratio might not be right depending on the housings.
Sizing is about right, but the housings are too small. At any rate you would need a new exhaust housing, sounds like that is a non-gated .48 AR which would be terrible.
94- You have to remember those ricers are turning x2-x3 our RPMs. Its common to see hx35s and hx40s on ricers, hx50s on the bigger ones.
No welder pretty much makes a custom project a no-go
Sparkplugless
09-22-2012 08:12 PM
Sharpshooter77
12-12-2008 08:03 PM
