Hey guys so in my gage cluster non of the lights work not even the heat and ac lights. All the Gage's work fine but non of the lights work. Could it be the head lamp switch? All the fuses are good to hope u guys can help me out this had been one that's stumbled me up
I'm not experienced on this generation of trucks, in fact still learning myself, but
I suggest checking your ground wires, but alas I cannot tell you where they would be located (perhaps someone else will reply with a location). Guessing they might be under the dash somewhere.
In my F150 none of the HVAC lights worked and half the cluster lights were out. All the bulbs were blown the and PO didn't seem to care. Its worth checking
How did you test your fuses, The best way is to set your meter to ohms. You want to have less than 5 ohms. If you have more than that pull the fuse out and retest it.
If you don't have meter just swap the fues around and see if you fix anything
Check fuse, the whole dash circuit is on one fuse. Also verify the headlight switch/dimmer is working and not causing zero power to go out to the circuit.
