40 degrees. Hard to start
Old Apr 9, 2013 | 08:18 PM
steelcutter58's Avatar
steelcutter58
1999 f350 7.3 deisel. Hard to start at around 40 deg. White smoke when starts and a little blue smoke. Would the ipr cause this.
Old Apr 9, 2013 | 08:29 PM
carltonwebb's Avatar
carltonwebb
Steelcutter, glad to see u on FTE.Welcome...Can I suggest you open a new thread and you will likely get a lot more responses than reopening a 3 yr old thread.
I bet its probably either your GPR or glow plugs. I attached a link to help u troubleshoot. Does it crank fine when plugged in?
https://www.ford-trucks.com/forums/4...ke-thread.html
Old Apr 10, 2013 | 01:15 AM
Stewart_H's Avatar
Stewart_H
I got it covered. I moved the posts and started his own thread for him.
Stewart
Old Apr 10, 2013 | 05:05 AM
Tugly's Avatar
Tugly
If you have a lot of miles on your injectors - like 180K or more (depending on frequency of oil changes), your injectors may be getting tired. Switching to 5-40 can extend the life of the injectors, but if you are truely to this point... start planning for an injector swap within about 20K-40K miles.
The glow plug system may be failing, get a meter on your batteries or in your cigarette lighter. The reading while sitting should be just over 12 volts. When you first turn the key, the glow plugs should be active, drawing a lot of current and giving a drop of about a volt (over 11 volts). After the truck is running, the voltage will rise a bit for up to a couple of minutes, then jump to 14.2 all of a sudden. This is usually a good indicator that the GPR system is working, but that doesn't promise all 8 are working.
These are the two biggies that get most people. I have that last link in my signature, it is very helpful.
Northernroots122
Aug 20, 2016 09:25 AM
tjc transport
Dec 31, 2014 05:55 PM
kt19
21
Jan 9, 2014 11:17 AM
Mike F250 SD
Nov 7, 2010 10:35 AM
plgebbia
Oct 9, 2010 10:56 AM
