Never seen one do that before...
Old Apr 10, 2013 | 11:14 AM
Oscar Walker's Avatar
Oscar Walker
It seems to only happen once its up to operating temps. How exactly does one test an ignition control module anyways?
Old Apr 10, 2013 | 11:53 AM
roadrash63's Avatar
roadrash63
Take it to an autozone or other parts store.free !
Old Apr 10, 2013 | 03:06 PM
Skoiv's Avatar
Skoiv
I've had good luck with my Echlin from Napa.
Old Apr 10, 2013 | 05:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The pickup coil in the distributor can crack, and open up while hot.
I've had this happen to me.
There should be 450-950 Ohms across the orange and purple wires of the DS II harness going to the dizzy.
Check when it has failed, and before it has a chance to cool off.
Old Apr 10, 2013 | 07:48 PM
Oscar Walker
Started acting all out of sorts on the way home, I finally pulled off and called a wrecker, not a chance I wanna wrestle that thing home in San Diego rush hour traffic with it quitting on me every 5 minutes. Gonna take it to a garage tomorrow and let them sort it out.
Old Apr 12, 2013 | 09:04 PM
Oscar Walker
Decided to give it one last shot before I took it to a garage. Pulled the distributor and checked it and the pickup coil. Both looked a little worse for wear and from what I could see, the coil definitely needed replacing. Checked the local parts store and they wanted $30 for just a pick up coil and $45 for a complete re-man distributor. Went with the distributor to save myself some time and trouble ($37 after military discount) and ended up paying $7 not to have to hassle with pulling the pickup coil and replacing it, just drop in the new distributor and fire it up. Fired right up like a champ and gave no indication whatsoever that anything was amiss. Gonna take it for a lengthy test drive late tomorrow night when the roads are empty to make sure all is well. On the plus side of things, the only thing left in that particular area that hasn't been replaced is the wiring between the module and distributor so if it acts the fool again, I know where to look first.
Old Apr 12, 2013 | 09:11 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Where you able to Ohm out the pickup?
If so, what did it read?
Old Apr 12, 2013 | 09:23 PM
Oscar Walker
Wasn't able to put a tester on the pick up coil, but it was visibly in bad shape and when I spun the drive gear by hand, there was noticeable variance in the distance between the pickup coil and thingamajig (the crown shaped piece that spins around on top of the distributor shaft)
Old Apr 12, 2013 | 09:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
'Reluctor Wheel'
That is a problem.
There is an 'air gap' measurement for spacing the pick up.
It sounds like you had a bent or sloppy distributor shaft.
Old Apr 12, 2013 | 09:34 PM
Oscar Walker
I am guessing that could potentially cause the engine to randomly drop dead with no warning?
Old Apr 12, 2013 | 09:46 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I would think it would be running poorly, sputtering etc...
But it shouldn't cause it to die completely if it is within spec at some point in its rotation.
The pickup is another story.
If it heats up and opens, it will stop the truck just as if you turned off the key.
Old Apr 16, 2013 | 09:12 PM
Oscar Walker
Allrighty, update time. After thinking I had everything fixed, Big Red left me on the side of the freeway again. Tired of messing with it (I can change just about any part on a truck and troubleshoot most issues, but I absolutely suck at electrical) I decided to just have it towed to my local garage. Turns out the wiring going into the horseshoe connection on the coil was way sketchy. The occasional bump in the road would make it lose enough contact to kill the engine. They soldered it up nice and spiffy and it runs like a champ now. (It damn well should, every electrical component under the hood has been replaced)
Thanks again for all the advice and guidance.
Old Apr 16, 2013 | 09:38 PM
  #28
1983F1503004x4's Avatar
1983F1503004x4
Glad you finally got it addressed. The horseshoe cap on my truck was covered in grease on the inside. I wondered how it even got spark.
Old Apr 16, 2013 | 09:48 PM
  #29
Skoiv's Avatar
Skoiv
1983... that grease was probably dielectric grease and was purposely put there. It doesn't take much and I put it on mine. Keeps rust from developing.
Old Apr 16, 2013 | 11:50 PM
  #30
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
In fact, I JUST replaced the horseshoe on my truck!
I too made sure to fill the pin sockets with grease after soldering on the replacement.
(my bad though. I snagged the ground 'tach' wire while doing my Saginaw swap)
One Sock
Apr 11, 2019 05:50 AM
Spoonman75
30
Oct 10, 2015 04:56 PM
Norton72
May 23, 2012 09:48 PM
76scout
Feb 24, 2008 06:23 AM
jdsdidit
Sep 9, 2007 09:30 PM
