Never seen one do that before...
Old Apr 8, 2013 | 05:25 PM
Oscar Walker's Avatar
Oscar Walker
Finally got the ignition and charging issues sorted out on my 85 F-250 (460 / 4spd) but on my way to work this morning, it showed me a new trick that I have not seen before, on any vehicle. At freeway speed (65-75, the speed of traffic since my speedo doesn't work) my truck randomly shut off several times. Rolling along and I suddenly look down and the tach is laying at 0 and there's nothing. Usually dropping it down a gear and is sufficient to bump start it, but bump starting while going 60 on the freeway in traffic is not my first choice of things to do to get the blood flowing. Think perhaps the ignition switch needs adjusted? Or perhaps a loose ground?
Old Apr 8, 2013 | 06:38 PM
Oscar Walker
Just did it to me a few more times on the way home from work. Most of the times I was able to pump the gas while it was rolling in 4th gear and it restarted itself with a healthy back-fire, but once it died completely and I had to coast it off the road and give it a sec before it would restart. Perhaps a fuel delivery issue, since it was still getting spark while rolling but apparently needed more fuel?
Old Apr 8, 2013 | 07:45 PM
1983F1503004x4's Avatar
1983F1503004x4
Sounds like the ignition module is going out on you. Mine just did this about a week and a half ago. I pulled my old module, stuck in a BWD module, and put in an Accel SuperStock coil on my 300.
You'll want to have your ignition module tested at a parts store to see if it's bad. If not, have them check the coil. If the coil is good, then check the distributor. Replace what's bad.
If you have to replace the ignition module, the aftermarket modules (unless it's OEM Motorcraft, $100+) don't have the spark retard during cranking, so your truck will start a little harder.
Old Apr 8, 2013 | 07:55 PM
Oscar Walker
the coil is about 2 weeks old, so I guess I'll start with the module
Old Apr 8, 2013 | 10:45 PM
Skoiv's Avatar
Skoiv
Mine did the SAME exact thing. It was in the wiring when the PO wired in an MSD box. It was a bad connection that would work and then cut out. Fought it and fought it. Finally got smart and went back to stock ignition box and checked all wiring and connections. All fixed.
Old Apr 8, 2013 | 11:52 PM
Oscar Walker
Replaced the ignition control module and drove it out to pick up dinner. Everything seemed to be in order but I suppose the real test will come on the way to work in the morning.
Old Apr 9, 2013 | 02:04 AM
joshofalltrades's Avatar
joshofalltrades
the tach reads the ignition signal into the coil, so if the engine is still turning but the tach reads zero, thats a problem in the distributor, module, or wiring.
the fact that it backfired when it came back to life, proves that its an ignition problem and not a fuel problem - unburned fuel accumulated for lack of spark and finally burned all at once when a spark came.
if the tach still gives a good reading when the engine stalls but hasn't stopped yet, then your problem would be in the connections at the coil, the coil itself, plug wires, or distributor cap+rotor.
and remember that new parts are not always good parts
Old Apr 9, 2013 | 06:25 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I can say with all certainty that the NAPA (Echlin) module I have, does retard while cranking.
Old Apr 9, 2013 | 10:39 AM
Oscar Walker
So far, so good. Drove to work this morning after replacing the ignition control module last night and no issues. If it makes it all the way home with no issues this evening, I'll call it fixed.
Many thanks to all who posted advice on this. I'd have to say this is easily the most helpful forum I subscribe to. I've been a member for about a month and have had 3 issues sorted out by you folks. Most forums are full of people who offer no help or advice but rather thrive on their own smug sense of self-importance and would rather be an *** than try to help anyone. Thank you all again.
Old Apr 9, 2013 | 10:55 AM
Skoiv's Avatar
Skoiv
Congrats Oscar. I think you fixed it. Feels good doesn't it!!
Old Apr 9, 2013 | 05:28 PM
Oscar Walker
Made it home from work with no issues, I'm gonna call this one fixed
Old Apr 9, 2013 | 09:23 PM
1983F1503004x4
As has been stated many times on this forum, the enemy of a DSII module is heat. If you want, take some rubber washers and use them to space the module up off the fender well a bit. It lets air flow underneath and help keep it somewhat cool. This is optional.
Huh! That's interesting. I'm going to have to look up the cost for that ignition module and compare that to what I paid for mine. I'm not going to yank mine out and go get the Echlin module, but if this new one goes out, I'm going to find another "new" one with the automatic spark retard.
Old Apr 9, 2013 | 10:41 PM
ctubutis's Avatar
ctubutis
I've been on forums like those you describe and don't miss 'em.
Thanks for the kudos, the immense knowledge & willingness of people to help is what makes FTE so great.
Old Apr 10, 2013 | 11:03 AM
Oscar Walker
Happened twice on the way to work this morning. Given that the coil and control module are both new, time to start looking at the distributor and wiring. Is there a way to troubleshoot a distributor to see if its bad or is it just one of those "it works or it doesn't" kinda things?
Old Apr 10, 2013 | 11:09 AM
1986F150six's Avatar
1986F150six
Unfortunately, some "new" electrical components are bad out of the box or do not last long. It may well be your replacement ignition module. That is why it is often suggested to pay extra for the Motorcraft unit. Take your replacement one to the auto parts store and have it checked. Be aware, though, that sometimes the module will check "good" while cold and will act up once up to operating temperatures.
Some have success with getting a used Motorcraft module from the junk yard for just a few bucks.
