Replacing spring shackle
Old Apr 7, 2013 | 11:32 AM
Furniture Doctor's Avatar
Furniture Doctor
Yesterday I replaced the spring shackle and bracket on my '96 F250. The bracket was mangled so I simply cut it apart. The shackle was a real PIA. The bolt and nut were seized and would not move even with PB blaster and the hot wrench. I ended up cutting everything off and replacing everything with new parts. I used two floor jacks and another heavy duty screw jack that I used to lift my house off the foundation. I did use jack stands to make sure everything was safe. The HF 4 1/2" grinder seemed like it was going to fall apart but I got the job done. Finally I tightened the 2 heavy shackle bolts after I put the weight back on the springs.
Doc
Old Apr 7, 2013 | 11:38 AM
fordman67's Avatar
fordman67
good job.did you get an oe or aftermarket bracket? i am curious since i see aftermarket if they are any good.
Old Apr 7, 2013 | 11:40 AM
Furniture Doctor
RE Spring shackle
I bought the brackets from a truck spring supply in Pittsburgh.
Old Apr 7, 2013 | 11:48 AM
fordman67's Avatar
fordman67
prob b pretty good quality i bet then.
Old Apr 10, 2013 | 12:24 AM
stainlessstroker95's Avatar
stainlessstroker95
I put my shackle kit on the other day too. I sure is hard to find 9/16 bolts any where.
Xcursion88
Apr 16, 2015 04:59 PM
Furniture Doctor
Apr 17, 2013 08:01 AM
andyj ford driver
18
Oct 1, 2011 01:03 PM
nissen4
May 23, 2008 08:53 AM
pancake
May 21, 2003 08:46 PM
