OD Light Blinking ONLY when at cold idle.
Old Apr 7, 2013 | 03:40 PM
Devilmanak's Avatar
Devilmanak
Project, I like your answer better than the wiring one. Lol.
It is raining, but I am going to suit up and go swap TRS from one truck to another. Want to get it fixed.
Funny thing, if the TRS is the only problem, I just scored. I talked the salesman down $2500 from the original dealed on price after they couldn't fix the problem, told him it may need a new tranny. Their mechanic put a brand new valve body in after reading the same codes I did, which makes ZERO sense to me.
NAPA has a TRS in town, if it is bad, are the NAPA ones as good as a factory Ford unit?
Old Apr 7, 2013 | 03:58 PM
Devilmanak's Avatar
Devilmanak
Heh. TRS out of my 212K mile 2000 Ex seems to have fixed it. Letting it idle for a while, but it didn't blink like it usually dose after a few seconds.
Old Apr 7, 2013 | 05:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's because you don't understand how a bad mechanic thinks. He knew how to change a valve body, they had one in stock, and he once fixed a trans by installing a new valve body. So that means a valve body will fix ANY transmission.
I'm with you, there was NO cause to change the valve body. He would have done more good by rotating the tires.
I would not hesitate to use a NAPA TRS. The NAPA part is probably the same manufacturer as the Ford part.
Old Apr 7, 2013 | 05:48 PM
Devilmanak's Avatar
Devilmanak
Lol.
Good, I just bought a NAPA one, it was in stock, the Ford ones on Ebay were a week to deliver. Going out to stick it on now.
Robsal
Jun 22, 2016 04:09 PM
E450 newbie
Dec 18, 2015 05:40 PM
Tyler.172
Apr 29, 2014 12:44 AM
jbizub5192
Jun 2, 2011 10:35 AM
98ranger2wd
1983 - 2012 Ranger & B-Series
Jul 24, 2006 10:53 AM
