Dim dash lights
Old Apr 5, 2013 | 03:17 PM
82fordowner's Avatar
82fordowner
Dim dash lights
My 82 f100 has very dim dash lights. I turn the light switch, it makes them dimmer but doesn't make them bright enough to see at night, could it be the light switch? All the bulbs are good! Thanks for any ideas to this problem.
Old Apr 5, 2013 | 03:30 PM
Ken Blythen's Avatar
Ken Blythen
This is one of the universal issues that all the 80-86 trucks suffer from.
Covering the bulbs in the dash cluster, are blue plastic domes that darken with age.
They can just be removed, giving you white light; or some owners remove the domes, then replace the white bulbs with blue or green.
Old Apr 5, 2013 | 03:56 PM
roadrash63's Avatar
roadrash63
Check your alternator and grounds
Old Apr 5, 2013 | 04:23 PM
86fn150's Avatar
86fn150
i ended up taking out the colored filters (they really dim it down)and just have white light
Old Apr 5, 2013 | 05:50 PM
82fordowner
Dim dash lights
Thanks everyone for the advice, think I'll take apart and remove the covers. First I'll check the alt. again thanks!!!!
Old Apr 5, 2013 | 08:10 PM
Franklin2's Avatar
Franklin2
It's the covers. Pull the cluster(be careful with the automatic PRND21 indicator, don't break it) Take the speedo cable loose, pull it out, twist the bulbs out, and take a pencil and stick down in the hole where the bulb went and poke the lens out.
Old Apr 5, 2013 | 09:20 PM
82fordowner
Dim dash lights
Thanks Dave f that's what I'll do.dont have to worry about the indicator I have a four speed Manuel
Old Apr 5, 2013 | 11:52 PM
randomguy's Avatar
randomguy
I have a similar problem.. in addition to the dimmer switch being really touchy. Will replacing the headlight/dimmer switch help resolve this?
Old Apr 6, 2013 | 06:48 AM
Franklin2's Avatar
Franklin2
It will help the control being touchy, and it might help the cluster lights, you never know, but when the headlight switch is working 100%, your dash still won't be as bright as any other car or truck you are used to. Those covers really get dark.
Old Apr 6, 2013 | 10:06 AM
JayzDaddy's Avatar
JayzDaddy
Anyone know the bulb #s off hand??
Old Apr 6, 2013 | 12:19 PM
82fordowner
Bulb number 194 or 194ll for my 82 f100 dash lights JayzDaddy
Old Apr 6, 2013 | 01:20 PM
JayzDaddy's Avatar
JayzDaddy
Thanks man. Headin to town later. May grab some blues or purples (daughters favorite color) to swap to after the punch out.
Old Apr 8, 2013 | 02:51 PM
1986F150six's Avatar
1986F150six
Some recommend getting the 194G bulb, when removing the filters. That way the instruments are still colored the same, but brighter due to the removal of the oxidized filters.
Old Apr 8, 2013 | 04:02 PM
82fordowner
Dim dash lights
I removed the blue domes off the gauges, works alot nicer but I may try the 194 g bulbs to have some color back on the dash. Thanks all for all the ideas.
bluesnake2006
Jun 21, 2015 01:34 PM
LawF250
1978 - 1996 Big Bronco
Sep 2, 2011 01:28 AM
Beaverman
Aug 27, 2010 01:39 PM
ramtoo
Sep 20, 2005 01:59 AM
manicmech
Nov 16, 2004 07:31 PM
