Dim dash lights
Old Aug 26, 2010 | 12:49 AM
Beaverman's Avatar
Beaverman
Dim dash lights
Ok I went in to my 85 f150 yesterday and cleaned all the contacts on the circuit behind the dash cluster and bulb sockets, replaced all the bulbs with new ones and now they all work, problem is the dam thing is so dim I can hardly read the speedo , read the other gauges, forget it!, I'm thinking it's the head light and dimmer switch assembly, what say ye? anybody else ever have this problem?
Old Aug 26, 2010 | 04:43 AM
Ken Blythen's Avatar
Ken Blythen
It could be the dimmer unit.....but the blue plastic lenses over the dash bulbs darken with age & block a lot of the light.
I took mine off - it makes a big difference if you don't mind the white lights. Some guys remove the plastic lenses, then fit blue colored bulbs
Old Aug 26, 2010 | 07:18 AM
f100jim's Avatar
f100jim
Another possible problem is that the colored plastic domes that the bulbs fit inside often darken with age. Most of mine are a chocolate brown rather than the nice green they started out as. I can barely see the dash lights. I am getting ready to pull the dash and remove the domes. I am going to switch to LED replacements.
Old Aug 26, 2010 | 08:13 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Those colored covers can make a huge difference in how well the dash lights work. I swapped the cluster in truck for one that came from a relatively low milage truck, and I couldn't believe the difference.
Many people pop those off, and then use either red or green tinted bulbs, available at most parts stores. Those who have done this, reported a huge difference in visibility.
Old Aug 26, 2010 | 08:39 AM
smashclash's Avatar
smashclash
those bulbs are expensive. are the LED's brighter than the stock type bulbs?
Old Aug 26, 2010 | 12:15 PM
TheKirbyMan's Avatar
TheKirbyMan
Also agreed on the bulb covers making a difference. My truck's original non-tach gauge cluster had some that were so brittle, one of them disintegrated in my hand when I squeezed it just a little (I was just observing it to see how it was made). Then just recently I picked up a very nice tach cluster from a junkyard, and it had absolutely perfect bulb covers. They're still like brand new, and let a ton of light through.
I ended up pulling the covers on my tach cluster though, and put in red 194s....it takes a little getting used to since it's a darker color, but it's very bright and easy to read, and looks great. The white lettering really stands out! I've heard it helps with night vision too.
Old Aug 26, 2010 | 04:04 PM
Beaverman's Avatar
Beaverman
all these comments make sense, thanks fellas, I take it that the domes are under the plastic that the circuit board is mounted to, must be easy to remove?
Old Aug 26, 2010 | 10:29 PM
ctubutis's Avatar
ctubutis
Yes,. Well, kind of... they're behind the gauges and are accessed from the front once you
remove the gauge bodies themselves (which are held on at the rear).
Old Aug 26, 2010 | 11:58 PM
TheKirbyMan
The speedometer is held in by two small hex-head screws on the back of the cluster. You can remove three of the five covers after removing the speedometer. Another tip, in order to remove the cluster from the dash, you have to disconnect the speedometer cable. You grab the white plastic cover where the cable connects to the gauge and press on the tab with your thumb. It should pull right out.
If you remove either the fuel gauge or the water temp gauge, you can remove the remaining covers. Each of the smaller gauges is held in with two small metal nuts on the back of the cluster. Be careful removing these, since they're also what connects the gauge to the circuit film.
Old Aug 27, 2010 | 08:16 AM
smashclash's Avatar
smashclash
that's not entirely true. I mean yes to "remove" the gauge cluster you need to remove the speedo cable but you can pull the cluster out far enough to change all the bulbs without having to remove the cable.
Old Aug 27, 2010 | 09:53 AM
Beaverman's Avatar
Beaverman
Thanks fellas, I've already have had the cluster out completely when I did the check and cleanup/ replacement of the bulbs, looks like this weekend it comes apart again and separated to get to those tinted hoods, gotta go, I'm thinking red bulbs should do just fine!
Old Aug 27, 2010 | 01:35 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Light bulb Industry number: 194-G is a good replacement bulb after you remove the plastic light filters as they are the stock color. Other colors are also avaliable.
194-G = Green
194-B = Blue
194-R = Red
194-NA = Amber
194 = white
194-LL = white, long life
The primary colors of light are Red, Blue and green, just like on your television. (RGB) All colors of light, and white can be made by mixing these three colors.
The plastic filters block the red light coming through them leaving blue and green. This leaves the stock blueish green look to the light. It also blocks the brightness of the bulb by 1/3. This is also why if you repaint the needles on your gauges you need to use a florecent red or flourecent orange. If you use regular paint the needles will look black, with stock color backlight, as there is no red light to reflect the red paint back. Florecent paint glows with any color light energy so that's why you can see flourecent red, even without red light being present.
hope this helps...
Old Aug 27, 2010 | 01:39 PM
TheKirbyMan
You mean without having to remove the speedo cable, or the big wiring connector? I've tried working on my cluster with the speedo cable still connected, and it was more frustrating than anything since I only had a few inches of space to put my hand through and try and fiddle with those twist-connect sockets...maybe it's just how my truck is set up, but it made it so much easier to work with after disconnecting the speedo cable, but leaving the wiring connector plugged in.
Awesome! I think you'll really like how the red bulbs make it look.
82fordowner
13
Apr 8, 2013 04:02 PM
itsjustagreat1
Feb 11, 2009 01:36 PM
nova_mxer
20
May 10, 2007 07:31 AM
Finnford
May 21, 2003 02:46 PM
CollinsCD
Feb 20, 2002 12:24 PM
