Dash lights
Old Sep 16, 2005 | 12:12 PM
ramtoo's Avatar
ramtoo
Dash lights
Anyone know of a way to make the dash lights brighter? Had a guy say once you could put a 6 volt light in there and put a resistor in line to kill 5 volts for a brighter light! Any Ideas?
Old Sep 16, 2005 | 07:16 PM
charles jones's Avatar
charles jones
I put a F650 or something instrument panel in mine and all the lights where bright enough except the turn indicaters. It had a 3/16 in thick colored lens behind it and I couldnt see it on in the day light. I just found some thin plastic material about 1/16 and cut new ones with my dremel tool and glued them in place of the originals. I can see them on in bright sunlight now
Old Sep 17, 2005 | 04:40 AM
jowilker's Avatar
jowilker
ramtoo, You do have the switch rotated counterclockwise to the point of turning on the cab light, right??
John
Old Sep 17, 2005 | 09:01 AM
rebocardo's Avatar
rebocardo
Change all the bulbs and clean the contacts. Mine are still a bit dull, but, I think t has more to do with the headlamp switch then anything else. Plus, the 194 is not exactly a bright bulb anyways.
Old Sep 20, 2005 | 01:59 AM
Cracker289's Avatar
Cracker289
I repainted the inside of my gauge cluster, the white was very faded and it had some rust. After repainting it, with new bulbs in place, the gauges are nice and bright.
1972-34ton
Electrical Systems/Wiring
Jun 19, 2017 06:29 PM
Supercab
6.4L Power Stroke Diesel
May 12, 2015 10:17 AM
brent1204
1983 - 2012 Ranger & B-Series
Mar 26, 2014 10:57 AM
brucefanz
Jun 9, 2009 01:25 AM
hydro_37
Modular V10 (6.8l)
Mar 29, 2007 08:09 AM
