I found one diagram on the Ford web site, but I can't get it blown up enough to see if I have all the parts. I am putting the stock unit back on the truck. Anyone have a better diagram?
I have a Bully Dog on there now. Does anyone know if they came with the clamps for the box or if they use the stock ones? All but one clip fell off the Bully Dog air box.
Thanks,
You need
Filter
Filter End Caps x2
4 small clips that hold filter to end caps 2 @ each end cap
1 big hose clap
1 hose @ Front end cap
1 filter minder @ Rear end cap
The rear end cap also Houses the MAF & IAT #1 Sensors
Note IIRC that 05+ Dont have the MAF Dont quote me on this though
You should still have the Rear Flex Peice that comes off the Rear End Cap the flex peice is s separate peice
You can see in these first few pics how I am taking the air filter out all in ONE Peice (Filter is Still Attached to the End Caps just undo the Big hose clamp) I have found this is the Fastest and Easier for me this is also how lots on here do it to
There are always some that do it diffrently and just unclip the filter in the Hole and Only Pull the Air filter out
FILTER MINDER
I may have some better ones if I find them I will post them up
