Crankcase breather missing part?
Old Feb 5, 2017 | 11:21 PM
ford300fan's Avatar
ford300fan
1990 f150 4.9. Factory air box has a hose from the valve cover going to the side of the air box to the crankcase breather filter inside. But the hose don't fit the crankcase filter. Is there a adapter I'm not missing to hook it up?
Old Feb 6, 2017 | 12:16 AM
ChRoNo16's Avatar
ChRoNo16
No, someone probably put in the wrong breather filter.
Old Feb 6, 2017 | 11:35 AM
rla2005's Avatar
rla2005
Maybe..most likely you are missing the plastic elbow that snaps directly on the crankcase filter.
The upper photo shows the small elbow on the end. I believe you can get one in the Help! section at your local automotive parts store. The Ford part number is 388962-S. There is a small retainer clip to hold it in place, Ford Part# D1AZ-9E628-B
Old Feb 6, 2017 | 08:14 PM
ford300fan's Avatar
ford300fan
Thank you! My air box never had a elbow on the breather filter since I owned it. I knew it had to be something.
cmb2481
Jan 11, 2016 03:49 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Jul 31, 2012 09:51 AM
TJ Johnson
Sep 21, 2010 06:14 AM
jbjb5081
Apr 10, 2004 09:13 PM
luke_trash
Apr 11, 2003 01:23 PM
