460 distributor woes
Old Nov 21, 2006 | 07:38 AM
dlister's Avatar
dlister
I have a 460 with the Holley projection TBI and I need a TFI distributor to interface with the ECM. I was told I could use a 351 W TFI and just change the gear. Does anyone have any experience with this?
Old Nov 21, 2006 | 01:07 PM
monsterbaby's Avatar
monsterbaby
I have heard that rumor too, not sure if it's true or not, but you can get TFI distributors for later model 460s without any trouble.
Old Nov 28, 2006 | 11:29 AM
dewlister's Avatar
dewlister
Had to reregister as a new user my acount went nuts. I have not been able to find a TFI distributor for 460 anywhere. Have any suggestions where to find one.
Old Nov 28, 2006 | 11:38 AM
monsterbaby
your local autoparts store would be a good place to start just ask for a dist for a 92 or newer F350 with a 7.5L in it. That is of coarse if you can't find one of those in a wrecking yard.
Old Nov 28, 2006 | 01:23 PM
dewlister's Avatar
dewlister
Yeah, I have already tried. Apparently one company rebuilds distributors for about all the part stores around here and they don't offer a TFI for a 460. However a 351 W is available. I even tried after market. Ford wants $850.00 for a new one. I can take my 460 distributor in and compare to a 351 W and go from there just didn't want to have to order one in without a pretty good Idea it would work.
Old Nov 28, 2006 | 07:25 PM
RTM's Avatar
RTM
Not sure if I will have time tomorrow but I just broke a 460 down for parts and I have a 351W roller that will be broke down for parts as well sitting right next to the 460. if weather permits I will compare the two dizzys for ya.
Old Nov 29, 2006 | 07:17 AM
dewlister's Avatar
dewlister
Thanks I appriciate the help
Old Nov 29, 2006 | 05:38 PM
RTM's Avatar
RTM
Didn't have time today. Matter of fact I didn't make it to the shop at all. Maybe tomorrow.
Old Nov 30, 2006 | 07:25 AM
dewlister's Avatar
dewlister
thank you, your help is greatly appriciated.
Old Dec 1, 2006 | 01:07 PM
RTM's Avatar
RTM
I stuck the 351W dizzy in the 460 block and it went right in. The seal is tight around the block opening just like it should be. The 460 is of the 80 something and the 351W dizzy I used was from a 94 model van motor. The 351W was did have an over all longer shaft at the end where the oil pump rod fits in but that didn't seem to be an issue. The dizzy cam gears are different.
Old Dec 4, 2006 | 12:44 PM
dewlister's Avatar
dewlister
I very much appriciate the help.
DPDISXR4Ti
18
Jul 31, 2019 04:37 PM
richardfine
WTB - Parts & other
Feb 15, 2017 01:19 PM
bbf385
Aug 6, 2014 05:23 PM
grego
Electrical Systems/Wiring
May 9, 2010 09:35 AM
dcassidy
Sep 28, 2009 09:12 PM
