General Automotive Discussion
06 Missfire
Old Mar 31, 2013 | 12:55 PM
jer365's Avatar
jer365
06 Missfire
I know I am in the wrong forum but have gotten no response from the correct one.
my 06 f-150 5.4 v-8 has a misfire in #4 the mechanics that I have taken it have no clue what else to change, we have done the plugs twice and 2 of the fuel Injectors, still has the missfire around 50-65 initially but then it seems to be only around 70 - 90 if I get on it. Help please.
Old Mar 31, 2013 | 08:26 PM
Ford_Six's Avatar
Ford_Six
How is the compression on that cylinder, and is there any valve noise?
Old Mar 31, 2013 | 08:32 PM
jer365's Avatar
jer365
They have not checked the compression that I know of, have replaced sp twice, and fuel injector on that one as well as number 8. What noise would the valve make?
Old Mar 31, 2013 | 09:23 PM
fixnair's Avatar
fixnair
A burned valve wouldn't make any discernible noise. An experienced auto tech could probably hear a burned exhaust valve in the exhaust pipe. I Had an '02 Lincoln Continental, 5.4 that kept throwing a cyl #6 misfire. Like you I swapped injectors, plugs and coilsW/O success. I finally gave the engine a compression test and #6 cylinder was way down to 60 psi.
Old Mar 31, 2013 | 09:54 PM
jer365's Avatar
jer365
have not done a comp test on 4 did on 8 when it was misfiring but that was normal, thinking a valve spring is what the mech said tonight does anyone know of a way to test the spring to be sure?
Old Apr 1, 2013 | 01:16 AM
Ford_Six's Avatar
Ford_Six
It'll just not close the valve, so the compression will be very low. You can pull the cam covers and visually inspect everything, but that will take time.
By valve noise I mean a ticking indicating there is extra clearance somewhere.
What is the vehicle actually doing when the check engine light comes on, or when it's obviously misfiring? Rpm, throttle position, etc-
Old Apr 1, 2013 | 02:02 AM
paverunner's Avatar
paverunner
Once the local guys give up your on your own. Think! I would go spark plug wire, distributor cap contact,fuel pressure, etc. Make friends with a real mechanic.
G
Old Apr 1, 2013 | 05:34 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
G
Welcome to FTE.
No caps or wires here my friend. Ford moved away from the dark ages about 10+ years ago. It's all electronic now.
Ranger Bob
Nov 6, 2017 06:57 AM
78fordman
Jul 2, 2017 10:08 AM
zel0
2004 - 2008 F150
Apr 14, 2017 05:17 PM
rowdyredneck
Nov 1, 2013 07:22 AM
drguitarum2005
2004 - 2008 F150
Jan 2, 2013 10:11 AM
