Engine chatter
Old Jan 1, 2013 | 09:55 PM
drguitarum2005's Avatar
drguitarum2005
Engine chatter
I went to go look at a 2005 F150 today with the 3v 5.4 and when it was warm and running noticed a slight chatter. It sounded like noise from the valve train or something. I asked the owner about it and he said it's always done that and his buddy's 09 does the same thing. Without hearing it, is there something common in these engines that makes noise? I can do spark plugs (even on this engine) but if it's in the valve train or something...I'd rather pass.
Thanks!
Old Jan 2, 2013 | 10:11 AM
MCDavis's Avatar
MCDavis
The injectors do make a slight "clicking" noise as they open and close. What you really need to watch for on 04-05 and some early 06 is the cam phaser noise. If it chatters like the clack of a small diesel at all RPMs then run away...fast. A slight click through the RPM range is typically the injectors.
astembridge
May 10, 2013 06:19 AM
celliott
2009 - 2014 F150
Feb 2, 2011 01:30 PM
topwhop
2004 - 2008 F150
23
Jun 5, 2010 05:28 PM
06F150Guy
2004 - 2008 F150
May 17, 2009 10:16 PM
jakano
2004 - 2008 F150
Oct 16, 2004 10:40 PM
