hh i havent seen one untill besides this one a buddy of mine said he sees them all over the dfw area so i guess its diffrent color schemes for diffrent areas in the country?
Is it green-white-green or white-green-white? I always thought the green-white-green was a common north / midwest scheme. I know in the four-corners states, the various tan, brown, gold combos (desert colors) are big.
i do but my phone is turned off for a bit work is tight atm, but it was a slight miss. It could be a weak injector thats what i was told but i decided to clean the system and sure enough there was trash in the screen. On the side of the fuel bowl there are 2 1o millimeters bolts thats the fuel pressure regulator. Unbolt it then pull it back with steady light pressure when you clear the oring pull up on it and itll slide off of the fuel line. But to pull your bowl its only three hose clamps one electrical connector and 2 bolts that come out with a 6in extension with a 1/2 on the other end.
yeah, I just haven't had the time to dig into the fuel system yet...
if you can get access to that video, i'd love to see/hear it. I can shoot you email address or phone number if you want to just send it direct rather than upload to youtube...
