learning as i go.
Old Apr 2, 2013 | 03:26 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by 75Three90
Eh itll be alright when i put my tank in the bed im going to rout it to the transfer pump
I have no clue what your calling a "transfer pump", but the valve on the frame is simply a selector valve.. We only have one fuel pump on these trucks and it's in the valley of your engine.......
Old Apr 2, 2013 | 08:14 PM
75Three90's Avatar
75Three90
Well the selector valve.geeezzzz whats with all the technical mumbo jumbo,latly.
Old Apr 2, 2013 | 09:59 PM
strokin'_tatsch
It confuses people when you can't give a decent explanation of what you got going on. Lol
Old Apr 2, 2013 | 10:19 PM
75Three90's Avatar
75Three90
Glenn knew what i was saying lol. Hey trav did you ever finish that badass 4x4 you were working on that single.cab short bed orange.one or.was it redish
Old Apr 3, 2013 | 01:48 AM
strokin'_tatsch
It got finished for all of about 1500 miles and then the engine melted the number 5 piston. Now swapping from 302 to a 408. Lol. Engine is being built right now.
Old Apr 3, 2013 | 08:07 PM
75Three90's Avatar
75Three90
Jesus christ trav wtf go with a 460 and call it.good
Old Apr 3, 2013 | 09:39 PM
oldbird1965's Avatar
oldbird1965
IDK, is there room for a 460 in a F150?
Old Apr 3, 2013 | 11:18 PM
75Three90's Avatar
75Three90
Same amount of room as a f250 or a f350 there aint no diffrence in engine compartment room but the perches would have to be changed.
Old Apr 3, 2013 | 11:19 PM
strokin'_tatsch
Plenty of room for a 460, but I'm not about to change the trans and everything to make that happen.. lol. A 500hp 408 will be plenty
Old Apr 3, 2013 | 11:26 PM
75Three90's Avatar
75Three90
Thats what you said about the 302.
Old Apr 4, 2013 | 12:29 AM
strokin'_tatsch
The 302 wasn't a 500hp built engine and it failed because it ran lean on a cylinder. I just have the itch to go bigger, so bigger it is. The 302 was only about a 315hp engine and I'm now used to a 500hp truck anyways. Lol
Old Apr 4, 2013 | 01:44 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OP - i'm curious about your fuel pressure regulator screen fixing an engine knock. I have a knock in my engine - sounds like its coming from the passenger side and is most apparent at idle and goes away at higher RPM. Its nothing too major and is worse when the engine is cold, but every time I hear it it makes me think its something I should address.
i'm still not totally convinced its not a bend rod, but i'm pretty sure that would get worse/louder at higher RPM. I checked all the rocker arms and rods real quick when doing my glowplugs in the fall. nothing major going on there, but I could have missed a slightly bend rod, I guess.
I hadn't thought that it would be fuel pressure related, but your post makes me wonder. my fp was good at the Schrader valve, but if the screen is after this test point, it still could be low going to the injectors... i'd really rather not tear into my fuel bowl as i'm saving up for e-fuel sometime soon and would rather just junk the whole mechanical setup before doing any work to it....
you don't have any video of your knocking prior to your fix do you? I need to get some video of my engine posted to see if someone can help me diagnose, but I'm not on youtube so have been putting it off...
Old Apr 5, 2013 | 08:19 PM
  #28
75Three90's Avatar
75Three90
i do but my phone is turned off for a bit work is tight atm, but it was a slight miss. It could be a weak injector thats what i was told but i decided to clean the system and sure enough there was trash in the screen. On the side of the fuel bowl there are 2 1o millimeters bolts thats the fuel pressure regulator. Unbolt it then pull it back with steady light pressure when you clear the oring pull up on it and itll slide off of the fuel line. But to pull your bowl its only three hose clamps one electrical connector and 2 bolts that come out with a 6in extension with a 1/2 on the other end.
Old Apr 5, 2013 | 08:26 PM
  #29
75Three90's Avatar
75Three90
btw ive never seen another truck with my two tone, its an emerald green metallic and white two tone.
Old Apr 6, 2013 | 12:31 PM
  #30
strokin'_tatsch
Robert, that two tone is kinda common.. I've seen a bunch of trucks with that scheme.
