Rear Main Seal Replacement
Old Mar 30, 2013 | 09:19 AM
troy676's Avatar
troy676
Im going to be replacing my Rear Main Seal in My 2004 6.0 diesel truck here shortly. Was wondering if anyone has the dim. of the Crank Bolt Pattern as to where the Installion Tool mounts? I plan on making the tool and Id really like to have it made Before I start, the replacement. Thanks for any info.
Old Mar 30, 2013 | 09:41 AM
Tom's Avatar
Tom
Hi Troy,
I'm sending this one down to the 6.0L forum, the folks down there will have a better time answering this one. How do you know your rear main seal is leaking? Lots of things on a 6.0 can leak and drip down the back of the engine.
Old Mar 30, 2013 | 09:53 AM
troy676's Avatar
troy676
Thanks for sending this to the proper forum. Ive had a pretty good look at the back of the engine and i dont see any real amount oil there, and ive read where the 6.0 is sometimes prone to leaking at the seal. Thanks again.
Old Mar 30, 2013 | 10:30 AM
Piolet's Avatar
Piolet
If your 2004 is the early one with the ICP under the turbo, that can be a source of on oil leak at the back of the engine.
Old Mar 30, 2013 | 10:37 AM
troy676's Avatar
troy676
ill have another look, Thanks
Old Mar 30, 2013 | 11:33 AM
the_auto_tech's Avatar
the_auto_tech
Could also be the bedplate as well.
Old Mar 30, 2013 | 12:44 PM
troy676's Avatar
troy676
so that means the motor would have to come out
Old Mar 30, 2013 | 01:16 PM
Yahiko's Avatar
Yahiko
Also if you do take on the seal replacement DO NOT REMOVE the inner set of bolts
on the end of the crank shaft. So it's a good idea to find manual or go to some place like
like Alldata.com. Chiltons and Haynes manuals are not worth the paper that they are
printed on. They lack detail on this motor.
Sean
Old Mar 30, 2013 | 01:32 PM
the_auto_tech
Yes. Thing is though that a lot of people here have found that if they run 13.5-14 quarts of oil instead of 15 that it seems to slow or stop the slow leak from the bedplate. Also, unless it's leaving spots on the ground I would simpy leave it.
Old Mar 30, 2013 | 04:45 PM
troy676's Avatar
troy676
Great Ill have to go to that site, thanks for the info.
I get about 3 or 4 drips, depending on far its been driven.
Tudunka
Feb 12, 2011 09:10 AM
Stang5lgt
31
Jul 8, 2007 04:35 PM
rutang
21
Jan 17, 2007 08:33 PM
77ford guy
Nov 9, 2006 11:51 PM
Daryl Hunter
Nov 7, 2004 01:41 PM
