1966 - 1977 Early Broncos
firewall boot replacement
Old Mar 29, 2013 | 07:54 AM
hotrod351's Avatar
hotrod351
has any one replaced the steering column firewall boot. just ordered one and trying to figure out how it slides over the shifter arms.
Old Mar 30, 2013 | 05:59 PM
kobaltblue's Avatar
kobaltblue
You have to pull it apart....No good easy way of that.
Old Mar 30, 2013 | 09:03 PM
hotrod351's Avatar
hotrod351
heat it stretch it. cut it. yeah cut it.
Old Mar 30, 2013 | 10:06 PM
kobaltblue's Avatar
kobaltblue
Cut it pac man style slip over then seal.
Old Mar 31, 2013 | 06:54 AM
hotrod351's Avatar
hotrod351
well ill see when i get it.
Old Apr 1, 2013 | 08:52 PM
chrlsful's Avatar
chrlsful
column condom
u CAN go from that end - pull the wheel & pound out the pin on the column end of the shifter. I might like that better'n disassembly of the other end & pullin the whole column. Depends on what U got there (auto/manual). Either way U hafta pull the 2 bolts on the strap column hanger & the ele plug.
I honor U 4 doin it. (better cabin temp, dryer, quieter, less mice & insects). I just went w/o.
Old Apr 1, 2013 | 09:54 PM
kobaltblue's Avatar
kobaltblue
Hay does that have a metal ring too? I was just out doing my power box and column mock up and I'm going to have to order one too but the PO had taken the steering column apart and I know some stuff is missing Flaming river stuff is spendy for something you cant see on a Bronco so I rather go with stock,Even though its a GM column
Flaming River Floor Mount Firewall Covers FR20100CVR - SummitRacing.com
Old Apr 2, 2013 | 08:11 AM
hotrod351's Avatar
hotrod351
no metal ring with the one i got. reused the old one. but i could see where the original one was attached to the seal with the ring.
Old Apr 6, 2013 | 01:19 PM
chrlsful's Avatar
chrlsful
column condom
ring? metal?
Got any pic?
99F-350CrewCab
Jun 20, 2016 07:51 AM
pimmy69
Sep 3, 2010 07:43 PM
slntnddly
Jul 9, 2004 09:57 PM
rje053103
May 2, 2003 12:32 PM
nigel6950
Apr 25, 2003 12:12 PM
