Radiator/ Temp Question
Old Mar 27, 2013 | 07:23 PM
outsource77's Avatar
outsource77
Question Radiator/ Temp Question
The truck 76, IL6 300, flairside, LWB. I need to replace the radiator due to a popped seam. There are two different radiator I can get a AutoZone. The regular one (smaller) and the HD version, three core. I measured, both will drop right in. Now,I have heard that the 300 will run more efficient on the hotter side of the thermostat. Should I go with what is in the truck now, smaller one, should I gowith the HD version or will the bigger one cool to much? Summer is on the way, west coast can get pretty hot. All thoughts and opinions are appreciated. Thanks
Old Mar 27, 2013 | 07:49 PM
montana_highboy's Avatar
montana_highboy
Why not take the radiator to a rad shop and have the seam resoldered, should be about $40-60
The oem copper/brass radiators are better quality than anything you'll find at Autozone.
Old Mar 27, 2013 | 08:01 PM
wyckedcombo17's Avatar
wyckedcombo17
If you've got the dough, get a three core. Your engine will keep a relatively constant 195 once its warmed up due to the thermostat's regulation of water temp.
As for warm/cold, yes an engine that is warmed up is more efficient, but if you're on the west coast you don't have to live with below zero temps, which is what kills efficiency (closed or 1/2 choke operation)
Old Mar 27, 2013 | 08:10 PM
lbcarguy's Avatar
lbcarguy
Repair your radiator
I concur with what was said on repairing your original radiator. It is a much more robust unit than what is made in China and sold here as a drop in replacement. Even if you end up needing a new core, you will have a radiator that functions and fits as Ford intended.
Hulk78
Jul 2, 2013 06:41 AM
outsource77
Mar 28, 2013 08:09 AM
Schuyles
Feb 12, 2012 11:09 AM
VENTUREMAN
Dec 9, 2008 12:47 PM
mark460
Jun 8, 2005 09:17 PM
