3 or 4 core radiator
Old Jun 8, 2005 | 08:08 AM
mark460's Avatar
mark460
I'm looking to buy a new radiator for my 77 f150 with a 460. Is the 4 core worth the extra bucks? Does anyone have any experience with the differences in a big block powered truck?
Thanks
Mark
Old Jun 8, 2005 | 09:15 AM
beartracks's Avatar
beartracks
I would always opt for the biggest radiator in a working, performance or large c.i. engine. I do live in a hot climate.
Old Jun 8, 2005 | 09:52 AM
Mil1ion's Avatar
Mil1ion
Living in a overly warm region it will be a benefit.
The shroud alone (which is required) for that rad runs about $200.00 +.
Old Jun 8, 2005 | 11:41 AM
mikebon08's Avatar
mikebon08
I'd get the biggest radiator you can--if the thermostat's working right it will take no longer to warm it up, and when you're stuck in traffic some lovely July afternoon, it could be very handy to have that extra cooling.
Old Jun 8, 2005 | 12:22 PM
mark460's Avatar
mark460
So, there is a different fan shroud for the 4 core?
Old Jun 8, 2005 | 12:42 PM
jstandle's Avatar
jstandle
I doubt it. I replaced my 3 core with a 4 core and my old shroud fit perfect.
Old Jun 8, 2005 | 12:44 PM
Bouts21's Avatar
Bouts21
I had mr rad recored and used the 4 core. Towed the travel trailer, total weight around 7000lbs, and had absolutely no heat problems whatsoever. It's on a 78 F250 Crew with a modified 400.
Old Jun 8, 2005 | 01:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have got actual figures somewhere. If I remember right it is in a Hayden design manual. A 4 core is about the limit for practical applications. A 4 core is not twice as effective as a 2 core. It has been a while but I seem to remember you get about 10% more cooling with a 4 core over a 3 core. Don't quote me on that tho. I will try to find the figures.
Old Jun 8, 2005 | 01:10 PM
Mil1ion's Avatar
Mil1ion
Yes the 3-4 core requires a different fan shroud than the 2 core does.
Old Jun 8, 2005 | 09:17 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
I'm running a 5 row staggered tubes vs 4 inline, it gets the tubes in the airstream vs heat from the tubes in front. Blocked off about half the radiator which would overheat a 4 row and the temp went up only a little amount.
68 F250 410ci. .....=o&o>.....
