Radiator
Old Jun 29, 2013 | 12:24 PM
Hulk78's Avatar
Hulk78
Radiator
I need to install a new radiator into my 1978 Ford F150 4x4. Is a aluminum radiator better to put in? I live in az so the weather here is pretty hot. I do not drive the truck everyday due to gas mileage, but I do drive when I need to or for the occasional cruise.
Old Jun 29, 2013 | 12:37 PM
Desarata's Avatar
Desarata
Red face just finished
1978 f150 4x4 new aluminum radiator along with a flo-cooler water pump and thermostat and a two speed mark 8 fan the temp stays in the middle no mater what I do idling, or running hard . bought my rad off ebay from monster cooling, the guy is a good guy had a problem and he took care of it right away . the weight of the new radiator is 22lbs which is a lot less than the old one.
Old Jun 29, 2013 | 05:49 PM
billgrant's Avatar
billgrant
Good Luck with that aluminum radiator. if you have problems with it the next time get a four core copper radiator called Desert cooler. It'll last you probably as long as you'll have your truck. Cost more up front, but you only need to buy one time.
Old Jun 29, 2013 | 10:34 PM
Blue and White's Avatar
Blue and White
My '78 F250 (400) came from the factory with a 2 core copper radiator. I recently replaced with a copper 3 core which was the factory extra cooling radiator. AZ fixed me up at reasonable cost.
Old Jul 2, 2013 | 12:26 AM
riverbedjedd's Avatar
riverbedjedd
I'm with billgrant get the desert cooler especially if you have factory a/c.
You will pay a little more I think i paid 325.00 but well worth it will last a long time. Good luck
Old Jul 2, 2013 | 06:41 AM
Desarata's Avatar
Desarata
Red face mistake
well after reading the forum input I think I brought the wrong radiator, whats the old saying " save a few bucks the first time going cheep---- making up for it the next time.
triumph1200
1947 and Older Ford Trucks
Mar 8, 2017 08:47 PM
John & Old Ford
13
Jul 28, 2012 11:04 AM
RedTaurus94
18
Oct 7, 2004 03:32 PM
JTdesert
13
Aug 9, 2004 12:49 PM
itlkick
16
May 22, 2002 04:05 PM
