Sponsored by: Auxito
Shifting into reverse problem
Old Mar 26, 2013 | 11:45 AM
Wish9955's Avatar
Wish9955
Exclamation Shifting into reverse problem
Just got a 98 f150 yesterday and I noticed last night when I went to shift into reverse, with the clutch all the way to the floor as I tried pulling the shifter back, it sounded like the clutch wasnt engaged at all. Shifting from all the other gears works just fine. Ive found that If the truck is off and I start it in reverse it works just fine. Any suggestions?
Old Mar 26, 2013 | 06:41 PM
R Pope's Avatar
R Pope
Try putting it in a forward gear first, then reverse. That stops the gears from spinning.
Those transmissions sometimes "block" reverse engagement somehow. Let the clutch out a bit when you go for reverse, it might slip in then.
Old Mar 27, 2013 | 10:29 AM
Wish9955's Avatar
Wish9955
It worked fine when it was warm out, then got cold again and it started acting up again
Old Mar 28, 2013 | 07:58 AM
R Pope's Avatar
R Pope
Not sure about Ford, but many hydraulic clutch setups are adjusted by simply hooking your toe under the pedal and pulling it up to the top of its stroke. Might try that.....
mtsnieg
Nov 20, 2023 09:56 AM
Wild-Bill
Dec 12, 2013 05:56 AM
Country705
Feb 11, 2007 08:45 AM
Stanstruck
1983 - 2012 Ranger & B-Series
May 11, 2006 07:46 AM
