Help!!
Old Mar 25, 2013 | 10:40 PM
Cody93idi's Avatar
Cody93idi
Help!!
Hey guys new to the page ok so my buddy broke the bolt off the plate to turn up the pump so long story short we had to pull the pump I took the pump off with the main gear and housing got the bolt out put it back on and it wount run it starts wicked hard and when it is run In it can bearly idle and it's billowing white smoke idk what to do this my 1st idi and it's my only truck need advice ASAP thanks
Old Mar 25, 2013 | 11:22 PM
4x4 ext.'s Avatar
4x4 ext.
Look at the gears. You should have a Y marked on the IP gear and a Y on the cam gear. They might both be dots instead of Y. Those have to line up. It sounds like your close but a few teeth of.
Old Mar 26, 2013 | 12:20 AM
kc0stp's Avatar
kc0stp
https://www.ford-trucks.com/forums/1...alignment.html
Ryan Weaver
Jan 18, 2015 05:10 AM
rideracelivemx7
40
Jun 7, 2011 07:17 AM
DIRTYSTEVEN
Feb 9, 2009 08:32 PM
Hiflyer746
Aug 7, 2008 12:23 AM
hiondeisel
Aug 20, 2004 09:10 PM
