computer reset while driving?
Old Mar 24, 2013 | 06:57 AM
lupuseven's Avatar
lupuseven
first off truck is running good 300miles since it happened.
I was driving @ moderate highway speeds 55-60 unloaded fairly steady throttle, suddenly the radio shut off so as we all do when something different is notice I checked all gauges. immediately I saw the gauges drop then run all the way over then back to normal. same as when the gauge check from the odometer thingy. engine was running fine durring this gauge "flash" then about 2mins later it did it again. none since, after the second one I ran through all the SGII values alll were in normal range.
is this a sign if things to come? I continued with my run an additional 200 miles w/np's. The next morning I did a chaffing check and found nothing.
thanks again guys!
Old Mar 24, 2013 | 09:25 AM
cheezit's Avatar
cheezit
2003/2004 like to do this sometimes. i have fixed the ones i have seen with a main engine sensor harness. checking for codes normaly comes up with a p0603 and or a p1000. you shoulkd also see the wait to start light cycly if its a true pcm reset
Old Mar 24, 2013 | 04:32 PM
lupuseven's Avatar
lupuseven
thanks cheezit!
I dont remember if the wait light was on or not. I did an imeadiate code check, no codes read. I check codes for the next 20 miles or so about every min as well. I have been debating on some harness replacements guess ill start there. no problem to warrant me wanting to do so, just trying to be preventative.
thanks again.
Old Mar 24, 2013 | 04:40 PM
cheezit's Avatar
cheezit
sorry i cant be of more help then a guess
Old Mar 24, 2013 | 05:56 PM
Misky6.0's Avatar
Misky6.0
Check if your trip meter reset to 0 , 300 miles ago?
Should help determine if dash lost power or
computer.
Old Mar 24, 2013 | 08:40 PM
lupuseven's Avatar
lupuseven
its all good I don't have any real hard data to relay, was a bit stunned and very scared.
Old Mar 24, 2013 | 08:43 PM
lupuseven's Avatar
lupuseven
computer.
Should have mention that too, bad customer... lay down, stay .
I did look at that, it was at the same mileage, did not zero out.
Old Mar 24, 2013 | 11:41 PM
Piolet's Avatar
Piolet
https://www.ford-trucks.com/forums/1...e-driving.html
I don't know if that helps. Similar situation.
Old Mar 26, 2013 | 07:25 PM
lupuseven's Avatar
lupuseven
thanks! very helpful.
will be checking all those connections soon as I get home and have some daylight :-)
c1goncalves
Oct 13, 2017 04:23 PM
Texas Chain Ring
15
Oct 22, 2012 03:22 PM
BIGGDDAVE
Aug 23, 2009 08:19 PM
Triple_E_Farms
1978 - 1996 Big Bronco
Mar 4, 2007 02:09 PM
motodube
Bronco II
Sep 23, 2006 01:42 AM
