Bronco II Ford Bronco II
hesitation
Old Sep 20, 2006 | 09:15 PM
motodube's Avatar
motodube
hesitation
anyone have any idea why a 87' 2,9l automatic would hesitate after every stop after driving around for about 3o min. it will start out fine, and the temp gauge wont go hot but it just comes out of nowhere and starts to hesitate until about the third gear. any help is very much appreciated.
Old Sep 20, 2006 | 10:56 PM
Dealford's Avatar
Dealford
Welcome to FTE !!!!!
This only happens after the engine reaches operating temperature?
Is the "Service Engine" light on and/or is the light working?
Check for codes.
AL.
Old Sep 21, 2006 | 01:59 PM
mrshorty's Avatar
mrshorty
'87's didn't come with a "service engine" or "check engine" light. Best first thing to do would be to pull codes from the computer and see if it's a problem the computer can see/has seen. Procedure can be found in Ken00's tech info post.
Old Sep 22, 2006 | 10:56 AM
motodube's Avatar
motodube
no codes
no codes show up
Old Sep 22, 2006 | 01:47 PM
mrshorty's Avatar
mrshorty
No codes as in the computer didn't respond to the test input trigger, or no codes meaning all pass codes?
Old Sep 22, 2006 | 03:08 PM
motodube's Avatar
motodube
all pass codes
Old Sep 22, 2006 | 10:48 PM
mrshorty's Avatar
mrshorty
EEC-IV isn't perfect at catching all faults, so there still may be some problem with the EEC-IV sensors. The fault just isn't far enough out of range. Of course, there are other possibilities, too. Checked for vacuum leaks? IAC valve and throttle body clean? Fuel filter free flowing? Fuel pressure correct?
Old Sep 22, 2006 | 11:47 PM
motodube's Avatar
motodube
i have all new tubes and the prssure check..ok
new fuel filter...but there is crud in fuel tank (could this be the problem) im using a cleaner everytime i fill up with gas)
fuel pressure checks out ho
Old Sep 23, 2006 | 01:42 AM
BCTom's Avatar
BCTom
I'd check fuel pressure. I put one can of STP fuel injection cleaner in at a fill up and wiped out the fuel pump. Hesitated intermitantely at various throttle positions at various times but only when warm. If you're putting stuff like that in your tank that could be something to think about.
