Adjustable Master Cylinder Pushrod
Old Mar 22, 2013 | 03:45 PM
BushyTea's Avatar
BushyTea
I switched my front brakes over to disk and of course the pedal sits a bit high. The rod on mine is the cylinder style and I don't have a welder nor do I know anybody with one to be able to cut and reweld.
So it seems my options would be to switch out the booster for a year that used the flat rod where I could drill another hole but I am not sure which year this would come from.
My other option would be an adjustable master cylinder pushrod kit. Has anybody tried these or know if they work?
SSBC A1726 Universal Adjustable Master Cylinder Pushrod Kit - Speedway Motors, America's Oldest Speed Shop
Thanks!
Old Mar 23, 2013 | 09:03 AM
69supercj's Avatar
69supercj
Not sure how much that kit cost but if you've got a tap and die set, a hacksaw and a left hand thread die and a turnbuckle you can make one yourself. Just be sure if you do to double nut it for safety reasons. I'd probably even use some loctite on it once you get the length correct.
Old Mar 23, 2013 | 11:49 AM
likeagoodbook's Avatar
likeagoodbook
Another easy solution is to block the booster bracket away from the firewall, I used two pieces of 1/4" steel on each side, drilled holes, mounted and all works fine.
Old Mar 23, 2013 | 01:22 PM
Jetcopterpilot's Avatar
Jetcopterpilot
The adjustable kits are a snap, and quite easy to dial in. just make sure once you get it where you like the throw, that you lock nut it tight, so it doesn't move on you...... It is a great solution!
Old Mar 23, 2013 | 02:29 PM
old broke prospector's Avatar
Take it to your local machine / weld shop. They can be a fantastic resource. Ask how much they will charge.
Our local one man shop charges $10 minimum for little stuff like that which should take him less than 5 minutes. He has been a life saver to the farmers and old iron fans as he can turn shafts for bearings, weld pretty much anything, and mill out replacement parts if you have an example.
DougJ_1997PSD
Aug 28, 2024 11:24 PM
Uni Moe
Oct 7, 2014 02:55 PM
mgargiullo
Apr 13, 2014 09:19 AM
Antony c.
Jul 28, 2007 10:00 PM
inliner
Feb 2, 2006 06:24 AM
