oil leak
Old Mar 19, 2013 | 08:12 PM
ryanelwood's Avatar
ryanelwood
oil leak
Oil coming off of torque converter dust shield, not sure where to start. Rear seal or rail plug on end of cylinder head? Not a major leak, just enough to frustrate me.
Old Mar 19, 2013 | 10:08 PM
ReBilld's Avatar
ReBilld
Look down in the valley on top the engine. If you have any leaks up there, it will run to the back of the valley and out a drain, down the back of the engine and come out of the inspection cover on the trans. Make sure it's oil and not fuel. Fuel leaks are common in the valley and by the time it runs down the back of the engine through all the grime, it will look like oil. If it is definitely oil that is leaking, look under the turbo on the pass. side and see if it's leaking around the actuator rod for the EBPV.
dothedew192
26
Jul 28, 2011 09:43 PM
Mdt1992
Jul 13, 2010 11:26 AM
LookoutRanch
May 24, 2009 06:51 AM
pushingxthexedge
Feb 16, 2008 06:19 PM
jimd2lman
16
Mar 21, 2005 08:10 AM
