K&N Completely Clogged
#32
WRONG!
K&N Mass Air Flow Testing Findings
K&N Mass Air Flow Sensor Test Results
K&N Product Warranties
If you don't know FIRST HAND what you are talking about and are just parroting misinformation you heard. Not trying to be a dick but you are ignorant about this. Air raid filters are much better, but a properly oiled K&N will always outperform an OEM filter.
#33
So again, if oiled correctly it's not an issue. That's like saying there is a race tire that gets a bad rap just because a bunch of 16 year olds die racing and flip their cars. If the tires were better "Performing" tires it wouldn't have happened. Blame the user, not the product unless it's just obvious that it's a real issue.
#34
Whether someone maintains an oiled filter correctly or not, which is almost plain luck, many car manufacturers will not honor warranties if they find an oiled filter or evidence of one. Now I know that no Excursion is under the original warranty but if car manufacturers react to them like that...
Its like JWC3 said (and I said earlier), oil will burn up MAFs and leave a nice oily trace all through the intake tract. Its not worth it.
#36
#37
#38
Well if you are a chopper mechanic , thanks for keeping our boys safe in the air . But , I have no experience in that area . So I can not speak on the use of oiled air filters in that app. But I can speak on their use in the automotive world . I know what I see , replace , repair . That is why I do not recommend them . I see what happens to sensors and drive by wire throttle bodies . I do not like to tell someone they need $700 in repairs because of an aftermarket oiled air filter . Reg joe puts one on , mucks up his air flow sensor . Then he cleans it , and soaks down his DBW throttlebody , for good measure . Then his throttle body shorts out and he needs a tow . Nissan is the worst . Might even take out the ecm when the tb driver shorts out ! That $89 filter just turned into $1200 repair . Those are some of the reasons I do not recommend them .
#39
#40
WPlayer
09-24-2010 11:08 AM
BajaB
21
07-30-2004 11:21 PM
