K&N Completely Clogged
Old Mar 18, 2013 | 07:22 PM
MuddyWaters's Avatar
MuddyWaters
Exclamation K&N Completely Clogged
I lost almost complete acceleration yesterday driving down a NM ranch road. Open the hood and find the K&N air filter is completely clogged. It was as if I had started the truck and immediately started driving it in 20 degree weather, except it was 85 outside when it happened and I had been driving for a couple hundred miles. I cleaned and oiled the filter thoroughly (per K&N cleaner instructions) 4 months ago. When the truck was idling it was almost choking itself out. I removed the filter and started the truck and everything was fine.
I drive a 01 Excursion, 7.3l PS. w 153k miles. I live in El Paso where dust is an issue. I would expect the filter to be very dirty but not so clogged that it would almost choke the engine out. Also, the intake pipe that receives the filtered air had a good amount of built up residue on the inside. I'm wondering if there is some underlying problem. Any help is appreciated.
Thank You
Old Mar 18, 2013 | 07:28 PM
m300diesel's Avatar
m300diesel
Has the vehicle stalled on you yet?
Old Mar 18, 2013 | 07:30 PM
Immortal_Ben's Avatar
Immortal_Ben
K&N's are said to perform poorly with silicates (sand). I do not use them anymore and have gone to AirRaid.
Old Mar 18, 2013 | 08:01 PM
Pickupmanx2's Avatar
Pickupmanx2
I run K&N's, but have heard that they suck in dusty environs,,, and yes, lots of driving on a dusty road, following folks, and passing them, and yes it will choke them down, got mine clogged with mud splatter once on my 94,,, freaked me out also.
Old Mar 18, 2013 | 08:18 PM
JWC 3's Avatar
JWC 3
OILED AIR FILTERS !!!!!! They cause many issues . Over oiled I suspect . Clean the K&n , run it dry , or buy a factory replacement . I have oil bath filters on my 50 and 53 . They are factory and work ok. Yours can lead to problems . The new style oiled filters are not good for Mass Air Flow sensors . They can also clogg in dusty conditions , especially if over oiled !
Old Mar 18, 2013 | 08:27 PM
MuddyWaters
My truck did not completely stall. I turned it off when it was choking out during idling. Seemed like it was on the verge though. I cleaned it out at the campsite I was at, drove to the first auto parts store and put a Fram in for now. I was unaware of the issue with sand/silicates and an oiled filter.
Old Mar 18, 2013 | 10:24 PM
double ott ex's Avatar
double ott ex
I suggest you install an ais filter. designed for dusty desert conditions, perfect for your driving conditions.
DOE
[FA-1759]Ford 7.3 liter Power Stroke Diesel AIS Extended Life Filter Kit(FA1759)
Old Mar 18, 2013 | 10:35 PM
Apocalypse's Avatar
Apocalypse
Originally Posted by JWC 3
OILED AIR FILTERS !!!!!! They cause many issues . Over oiled I suspect .Yours can lead to problems . The new style oiled filters are not good for Mass Air Flow sensors .
WRONG!
K&N Mass Air Flow Testing Findings
K&N Mass Air Flow Sensor Test Results
K&N Product Warranties
If you don't know FIRST HAND what you are talking about and are just parroting misinformation you heard. Not trying to be a dick but you are ignorant about this. Air raid filters are much better, but a properly oiled K&N will always outperform an OEM filter.
Old Mar 19, 2013 | 01:31 AM
Stewart_H's Avatar
Stewart_H
For years, rig owners with 7.3L diesel engines have been warned away from K&N filters because there have been many cases were turbo's and engines were dusted due to the poor performance and sealing of the K&N filter.
You couldn't pay me a monthly stipend to run one on any of my diesel rigs.
I strongly suggest you get rid of your K&N and replace it with any number of filter options that are better than that filter.
Stewart
Old Mar 19, 2013 | 08:27 AM
Bigpipes 35's Avatar
Bigpipes 35
Originally Posted by Apocalypse
WRONG!
I love how all of these tests were conducted by K&N , What else are they going to say our filters suck and they wreck stuff on you truck.
Old Mar 19, 2013 | 10:02 AM
Archion's Avatar
Archion
Veteran: Marine Corps
You should also be running some kind of pre-filter or sock in that kind of climate.
And I don't care what K&N says in their "paid for" independent testing, after years of dealing with EFI Ford and GM performance vehicles, you couldn't pay me enough to run one...
Old Mar 19, 2013 | 10:15 AM
az_r2d1's Avatar
az_r2d1
Same here. they suck !
Old Mar 19, 2013 | 10:16 AM
wrxin's Avatar
wrxin
I will never understand why people use oiled air filters. They are notorious for ruining intake systems past the filter (MASs, MAFs, throttle bodies, and intake runners on any number of different vehicles) and they can be quite difficult to get just the right amount of oil on them, not to mention the ongoing maintenance.
Oiled filters are also basically a useless performance upgrade, especially when its the only thing done to attempt to upgrade performance...
There is nothing at all wrong with an OEM style filter.
Of course if you believe all the marketing, go ahead...
Old Mar 19, 2013 | 10:30 AM
neilc88's Avatar
neilc88
...outperform an OEM filter.
By flowing more air due to less filtration.
Old Mar 19, 2013 | 10:32 AM
wrxin's Avatar
wrxin
Right, less filtration... <sarcasm on> sounds like a good thing <sarcasm off>.
