sync problem
Old Mar 16, 2013 | 04:39 PM
enchanter's Avatar
enchanter
sync problem
2010 6.0 e-series...replaced camshaft, lifters and front cover, now cam-crank sync is no most of the time but ficm sync is ok? cam timing is ok, crank sensor wheel is ok. replaced both sensors, wire harness and tried known good pcm and ficm......anybody got any ideas? HELP
Old Mar 16, 2013 | 05:34 PM
dannyboy950's Avatar
dannyboy950
If you were off by so much as a tooth when you put the gears in time you never will sync.
Old Mar 17, 2013 | 09:57 AM
enchanter's Avatar
enchanter
scope signals from sensors show cam timing ok ?
Old Mar 17, 2013 | 10:14 AM
dannyboy950
Then you may have a rare PCM failure. PCM's rarely fail it is useually the FICM's that have a high faliure rate. Also may be wireing between FICM and PCM.
Old May 8, 2013 | 09:58 AM
DCSAN20's Avatar
DCSAN20
Hi there anyone have a wire harness diagram for PCM and FICM for electrical power supply? and location of the relays and connectors ?
Old May 8, 2013 | 08:32 PM
lenzhotrod's Avatar
lenzhotrod
So you do sometimes show a good cam/crank sync? Do you always have a clean scope signal? If it comes and goes try cleaning the mounting surface for the sensors, just a little dirt or rust can give a bad or no signal. I've heard of loose tone rings but have never seen one myself.
Old May 8, 2013 | 10:16 PM
BLADE35's Avatar
BLADE35
I think this is a diffrent person
WIRE DIAGRAM FROM 6.0L BIBLE
SINGLE ALTERNATOR
Page 90: Wiring Diagram (Single Alt)
Page 91: Wiring Diagram (Single Alt)
Theres 2 Links for 2 pages^^^^
If you have no sync check FUSE#22
Old May 8, 2013 | 10:18 PM
BLADE35's Avatar
BLADE35
Give Rusty some reps he did Great
2006 6.0L Engine Relay and Fuse box info with pics
https://www.ford-trucks.com/forums/1...l#post12323713
free59mod
Nov 23, 2015 10:29 PM
randy stringham
Apr 11, 2010 09:24 AM
Modified 99
May 7, 2008 01:48 PM
Fasterhorses
1997 - 2003 F150
23
Apr 16, 2007 07:08 AM
mustangsvo85
Dec 5, 2006 08:32 PM
