Sponsored by: Auxito
Cam Timing?
Old Apr 12, 2007 | 07:12 PM
Fasterhorses's Avatar
Fasterhorses
Cam Timing?
Serious problem yesterday. Truck suddenly started sounding like every lifter was clattering. Scope showed timing was off. Mechanic pulled a valve cover and found the cam gear had turned on the cam shaft. He does not have the Ford cam timing tool set and says he can get the timing right by counting timing chain plaited links. Is that possible? He says both cams have to come out but only the drivers side is bad. Is he right? This is beyond my "shade tree" experience so any insight would be appreciated.
Old Apr 12, 2007 | 08:55 PM
LxMan1's Avatar
LxMan1
I don't know why the other cam would have to come out unless he is replacing both of them to keep the other one from doing the same thing shortly after replacing the bad one. It uses a key way to keep the gear from spinning on the cam. But you don't need to pull the cam to change that. Both timing chains will need to be removed.
Old Apr 12, 2007 | 09:14 PM
Fasterhorses
Thanks LxMan1,
So the timing gears can be removed and the keyway replaced and the gears pressed back on without removing the cams? This is a 97 5.4L. Do I definitely need the cam positioning tool?
Old Apr 12, 2007 | 10:32 PM
LxMan1's Avatar
LxMan1
Not sure on the tool, but the gears will slide on and off of the cams without too much trouble.
Old Apr 13, 2007 | 08:35 AM
Johnny Langton's Avatar
Johnny Langton
Not on a 5.4L.They're all Windsors and are pressed fit gears,not bolt-on.
JL
Old Apr 13, 2007 | 09:38 AM
Fasterhorses
JL
So...my question or problem is...how can I tell if the cam gear has turned on the camshaft? Can it be put back in the proper position and welded? Thanks for any input.
Old Apr 13, 2007 | 10:19 AM
duggyb's Avatar
duggyb
i would reccomend using the tool..my brother and dad were just inside his 4.2L V6...and they tried to do it without the tool and got it all backtogether and it wouldnt fire properley....they ended up buying the tool and using it then taking it back.
trucks runs great now!
THNX
Duggy
Old Apr 13, 2007 | 10:31 AM
Johnny Langton
THNX
Duggy
You don't need any special tools to change cams or retime a modular.
JL
Old Apr 13, 2007 | 10:34 AM
duggyb's Avatar
duggyb
well my brother and dad used a cam timing tool(im pretty sure thats what it was for)...it was a little black circular thing...cost about $35....maybe i am mistaken...i never used it..just seen him taking it back to the store..
could this have been for something else?
THNX
Duggy
Johnny Langton
There's no practical way to do it,short of having the engine out and degreeing the cams then welding the gears in place. Then you have to be concerned with welding the powdered metal cam gear-they're fracture prone due to their composition.My suggestion is to look for a set of cams from any PI 4.6L or 5.4L (Romeo or Windsor) and install them-they're all the identical same be it truck,car,etc.
JL
Old Apr 13, 2007 | 10:36 AM
Johnny Langton
THNX
Duggy
That thing is a joke,and you don't need it. A 3/8" square drive(extension bar) fits in the end of the cam perfect,and does the exact same thing-all you need it for is to turn the cam slightly to line up the chain links.
JL
Old Apr 13, 2007 | 10:38 AM
duggyb's Avatar
duggyb
hmm well we did not know this...but its ok becuase we took it back and got our money back anyways...so it didnt cost us nothing but the trip to the store.
thanks for the headsup on using a driver though...i will know for next time.
THNX
Duggy
Old Apr 15, 2007 | 03:44 PM
Fasterhorses
JL
Well the pressed on cam gear appears to be another money saving stupid idea by Ford. Spent hours at a wrecking yard looking at 5.4 heads and measuring cam lobes (97's are 2.04" & non-PI heads) and found several cams that had movement in the gears, the yard guy was amazed. Is that maybe why the engines were junked in the first place? Every cam lobe back to 98 (they had no 97's) was 2.18" so I am SOL so far on a junk yard cam. Another disturbing fact has come to light and that is the camshaft bearings are just aluminum and part of the head casting and not fixable. All of the bearings and shafts that I saw were quite scored and mine were the worst probably because mine was older. Spark plugs that blowout...cam gears that turn because of no key...cam bearings shot because of cheap metal...all within 10 years...looks like these are truly THROW AWAY motors designed for 100,000 miles I'm at 107,850.
Old Apr 15, 2007 | 04:20 PM
LxMan1's Avatar
LxMan1
The only one that I have actually had apart was a 4.6L in a 94 Cougar. it had bolt-on keyed timing gears.
Old Apr 15, 2007 | 05:27 PM
Johnny Langton
I've never had a problem with Windsors myself,and I had a set of '99 cams in mine and spun them to around 7K rpms in the Tbird. I don't buy the mileage idea either-I put 225K miles on my TBird with a helluva lot of beating and high RPMS on it with not a single problem with the cam journals,or anything else. The cam bearing surface on the head is repairable-several companies make a bearing kit for them-Dover cylinder heads I know for sure can line-bore then heads and do the machine work on them for the bearings.
You can swap in a set of '99-up PI cams,they'll work great. I've got '01 Romeo cams in my truck right now. The journals are all the same diameter,and the only difference in the cams is the lift-stock NPI are .472" lift intake and exhaust,stock PI are .510" intake and .530" exhaust. That'll gain 15-20 ft-lbs and a few hp while you're at it.
JL
