2003Exp 5.4 emission problem
Old Mar 14, 2013 | 10:57 PM
ShadowSnowLeopard's Avatar
ShadowSnowLeopard
Ok, to keep this simple, this problem started three years ago and I have just been working around it. My expedition apparently has a computer power problem somewhere. When they hook up to it for emissions, everything is great till they turn off the ignition, then on restart the computer is cleared like you have unhooked the battery and fails. What I have been doing is just turning the key back to accessory, not off. Kills the engine but doesn't clear the computer. Now, not a big deal I guess since I have inured out the work around, but has anyone else seen this? No error codes and no blown fuses under the dash.
Old Mar 15, 2013 | 05:23 AM
projectSHO89's Avatar
projectSHO89
Check the power feed from fusebox F5 to PCM connector pin 40 (red/white wire). It's supposed to be "always hot" and is used to maintain the PCM's Keep Alive Memory.
Old Mar 15, 2013 | 10:40 AM
alloro's Avatar
alloro
Check fuses 5, 28, and 41.
msp1972
Computer Chips & Tuners
May 1, 2017 08:59 PM
rmd8123
Jan 22, 2010 10:57 PM
mrb455
22
Oct 1, 2009 09:38 PM
briancowen
1978 - 1996 Big Bronco
Feb 28, 2004 09:38 PM
JimM71
Dec 3, 2001 11:50 PM
