Computer Chips & Tuners
My computer keeps erasing the stored codes
Old May 1, 2017 | 07:34 PM
msp1972's Avatar
msp1972
I have a 97 Ford F350 460 EFI. I fixed the problems with the lean conditions. I drive it around, it lets me know the fuel trims, no problem. The next day I scan with OBD II and the vehicle has no data stored. Battery is fine. Any suggestions?
Thank you, Michael
Old May 1, 2017 | 08:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a pin on the PCM called KAM power. If it doesn't have +12v on this circuit it will erase the codes every time the key is turned off. I don't have a diagram to be able to tell you which pin this is.
Old May 1, 2017 | 08:48 PM
Conanski's Avatar
Conanski
Sounds like the computer is losing it's keep alive power.. that is an always on feed to maintain memory on pin 55.
Old May 1, 2017 | 08:57 PM
msp1972's Avatar
msp1972
I will check this out. Thank you
Old May 1, 2017 | 08:59 PM
msp1972's Avatar
msp1972
i will look for that pin. Thank you.
p.s. but I do get to read the scan, it just goes away after a day.
jd4300
Aug 9, 2010 04:17 PM
SSCX2
Electrical Systems/Wiring
Oct 24, 2005 04:49 PM
palindromelol
Jun 28, 2005 06:03 PM
Frank Lang
13
Mar 27, 2005 07:15 AM
PHS79
Jan 13, 2003 09:47 PM
