fuel filter ?
Old Mar 13, 2013 | 12:09 PM
jmdjr67's Avatar
jmdjr67
fuel filter ?
2002 f350 7.3 diesel with 153,000 miles. Acts like its running out of fuel on hard acceleration. Is the filter in the vally pan the only filter in the system? The truck has also got a whine i have traced to the fuel pump in the frame rail on the drivers side. jmdjr67
Old Mar 13, 2013 | 12:35 PM
snakedoc's Avatar
snakedoc
there is a filter on the top of the motor, and a set of screens in the fuel thank that can get clogged. search hucth harpon to see how to fix the tank.
Old Mar 13, 2013 | 01:34 PM
howellt39's Avatar
howellt39
You could disconnect the fuel line at the back (input side) of the fuel pump and take your gas cap off and blow compressed air back into the tank. This will backflush the pickup screen, temporarily of course. If you have a sudden change (improvement) in performance that would indicate a clogged screen, and is much easier than dropping the tank to investigate.
Old Mar 13, 2013 | 03:05 PM
SpringerPop's Avatar
SpringerPop
Plastic tank or steel?
Pop
Old Mar 13, 2013 | 03:17 PM
snakedoc's Avatar
snakedoc
can a 350 have a plastic tank? all that i have worked on where.
Old Mar 13, 2013 | 04:45 PM
howellt39's Avatar
howellt39
FWIW, I've got a 350 and it's a plastic tank.
Old Mar 13, 2013 | 04:56 PM
jmdjr67's Avatar
jmdjr67
The truck has a plastic tank. It came that way, i have had the truck since new
Old Mar 13, 2013 | 05:36 PM
SpringerPop
As I understand it:
Standard pickup trucks, F250s and 350s, that came from the factory with a pickup bed have plastic tanks.
The cab-n-chassis F350s and all 450s and 550s came with steel tanks.
Pop
Old Mar 13, 2013 | 10:02 PM
snakedoc's Avatar
snakedoc
10-4 did not know the 350 could come with them.
Old Mar 14, 2013 | 10:47 AM
Supercab's Avatar
Supercab
Soooo, the plastic tanks are ok? and the steel ones are the ones folks have reported problems with the lining flaking off and causing a mess??
Old Mar 14, 2013 | 11:37 AM
snakedoc's Avatar
snakedoc
yes steel tanks like to shed there lining.
Old Mar 15, 2013 | 09:06 AM
Supercab's Avatar
Supercab
-Thanks, Wonder why Ford did this? different capacity for the C&C trucks?
-Are the short bed and long bed PICKUPS tanks all plastic?
-Certainly Bio-Diesel fuel won't eat the plastic??
Old Mar 15, 2013 | 10:13 AM
trekbasso's Avatar
trekbasso
Who the heck knows. But they are mounted behind the rear diff, where our spare tire is.
I have not seen reference to steel tanks on the side, except vans?
Many have run vo/bio for years so guess not.
Old Mar 15, 2013 | 11:02 AM
SpringerPop
I suspect it has something to do with the number of trucks created of each type. It would have been nice if they had created a plastic tank for the cab-n-chassis trucks, but they are a more-limited production. I suspect it's cost related.
Yes, both are plastic, but different lengths, thus different capacities.
I have heard absolutely nothing that would indicate bio-diesel has any adverse reaction on the plastic used.
Pop
jhinalabama
2009 - 2014 F150
May 18, 2018 12:37 AM
Jaynes
15
Nov 12, 2017 06:08 AM
Orpackrat
Jul 10, 2014 09:53 AM
sufferingant
May 13, 2010 11:29 PM
Bronco86
Jan 2, 2004 01:45 PM
