I was given an engine from under a semi trailer on a farm. It was rebuilt and has less then 1000 miles on it but has sat for 5 years with just a tarp over it. I was told it was a 1970's 351W but the numbers I pulled from the block came up as a 1967 429 Side-Oiler on the only website i could find with that number (C7AE-A). Can anyone help me? here are all the numbers i could find.
In between 2-3 Spark Plug on the Driver's Side: C7AE-A
Side of block under 1 Spark plug on the Driver's Side: 29 (upside down)
DIF
Driver's Side of the Water Pump: 29
352
The intake and water pump were not original to the block unfortunately.
Btw, the term "side oiler" is associated with the 427FE.. it has an horizontal oil galley along the passenger side to oil the mains. Technically speaking, plain ol' FEs, including some 427s (non-high performance), are center oilers.
A 351W has a vertical casting rib on the driver's side of the distributor hole. 289/302s do not.
Post a pic of what ya got and we'll go from there...
Had those same number on my old motor that I put in my truck in 1978 that came out of a 1967 ford wagon. 390 Fe that looks to have 360 intake & alternator double belt v-pulley heater hose outlet. The oil filter mount bracket looks like the oem 1967 390 model. The crank pulley& damper looks like 360 and not the early 1967 type..That's my 2cents...orich
That is a car setup with the front sump oil pan, it also has the mount bosses for the car mounts. 2wd trucks had a center sump pan, and 4x4 got a rear sump. 4x4 trucks also got a vertical oil filter mount, I have seen three now that were stock 4x4 installations with a vertical filter.
This was supposedly in a dump truck, it has a 4 speed granny with pto paired with it. What do I need to do to make it a 390 and not some Frankenstein monster lol. Thanks for all the help!
Dump trucks: 1964/78 F500/750's came with FT engines.
FT engines used the 3 point engine mounting system (as did 1965 F100/250 4WD, 1965/66 F350 & 1966 F250 4WD). Front center mount, R/L rear mounts.
4 speed with a PTO could be a Warner T-18 or New Process 435, installed in 1964/78 F500/750, 1965/76 F100/350.
Thank you NumberDummy for all the information I could need. I didn't know anything about this engine till today lol. I don't know if you saw but I have another post you could check out
